[Qgis-user] QGIS 2.8.2 GPS Tools and Garmin USB Connection
Antonio Di Marco
a.dimarco at arpat.toscana.it
Fri Jul 10 06:45:59 PDT 2015
Hi Lene thanks for your reply, the problem is not to open the GPX but is
to download data with GPS Tools plug-in to directly show waypoints an
the map.
It seems that GPS Tools doesn't recognize my garmin76Csx and so the
download fails.
Il 10/07/2015 14.35, Lene Fischer ha scritto:
> Hi Antonio,
> You can open a GPX- file as any other vector file. Just remember to
> choose the extension .GPX
> The plugin is not needed to open.
> Regards
> *Lene Fischer*
> Associate Professor
> *Department of Geosciences and Natural Resource Management*
> University of Copenhagen
> MOB +45 40115084
> lfi at ign.ku.dk <mailto:lfi at ign.ku.dk>
> cid:image001.gif at 01D03029.2F3EC6A0
> *Fra:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *På vegne af *Antonio Di Marco
> *Sendt:* 9. juli 2015 16:35
> *Til:* qgis-user at lists.osgeo.org
> *Emne:* [Qgis-user] QGIS 2.8.2 GPS Tools and Garmin USB Connection
> In QGIS 2.8.2 I couldn't download my Garmin GPS waypoints through
> Vector -- GPS Tools menu under an USB connection.
> The device has this Command line under "Waypoint download":
> %babel -w -i garmin -o gpx "%in" "%out"
> I tried also this line: gpsbabel -w -i garmin -o gpx "%in" "%out"
> In both cases I get this message:
> *Layer is not valid: *The layer xxxx.gpx?type=waypoint is not a valid
> layer and can not be added to the map
> I need an usb connection not a serial one via COM1
> To verify that was not a driver trouble or something else I tried to
> gat the waypoints via GPSBABEL and everything is ok
> Any answer will be very much appreciated
> Antonio Di Marco
> ARPAT (Agenzia Regionale per la Protezione Ambientale della Toscana)
> Direzione tecnica - Settore SIRA (Sistema Informativo Regionale Ambientale)
> Via N. Porpora, 22
> 50144 Firenze
> Tel.: +39-055-3206416 Fax: +39-055-3206324
> email:antonio.dimarco at arpat.toscana.it <mailto:antonio.dimarco at arpat.toscana.it>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150710/33118e04/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150710/33118e04/attachment.gif>
