[Qgis-user] Convert data DXF (autocad R12) to QGIS
Peteris Bruns
pb at sungis.lv
Mon Jul 13 06:04:22 PDT 2015
Hi Marco and Andreas,
if there is potential plan to use Teigha DWG Library from OpenDesign
Alliance, then probably is worth to include import support for
MicroStation DGN v8.
We are interested in this development. For sure we can provide test data
(DWG/DGN), and I believe we are ready something to fund also.
Best regards,
On 2015.07.02. 10:58, Andreas Neumann wrote:
> Hi Marco,
> In the soon to be released 2.10 version and also in the upcoming 2.8.3
> release (probably released in the second half of July) you can find a
> much improved DXF export.
> See http://www.qgis.ch/en/projects/dxf-export for more details of the
> DXF export.
> We will work on DXF/DWG import in the next 1-2 releases. We have
> started to work on a requirements document here:
> https://docs.google.com/document/d/1NJv1lwd5TnWdV-fTuW7g5ts1O8r3vb46xYeAIQ_BwGw/edit?usp=sharing
> Your input to the requirements document will be welcome. Also, we
> would appreciate if you could help finance this effort - if possible.
> We will soon ask a dev for a quote how much this will cost and then
> approach the QGIS users to help fund this effort.
> Note that it is definitely not possible to round-trip GIS to CAD and
> back. CAD data is not a GIS format and vice versa. But we will do our
> best to help bridge the two worlds.
> Best regards,
> Andreas
> On 02.07.2015 09:07, Marco Boogaard wrote:
>> Hello,
>> I want to convert DXF (R12) data to QGIS and vise versa.
>> Is this possible with QGIS? And do you need a plugin or script?
>> Thanks.
>> Regards
>> Marco Boogaard
>> www.gis-specialist.nl <http://www.gis-specialist.nl>
>> Schrijf u in voor de nieuwsbrief <http://eepurl.com/uybj9> en volg
>> ons op Twitter <http://www.twitter.com/gis_specialist>.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Pēteris Brūns
SunGIS
+371 26336691
pb at sungis.lv
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150713/2031d1b3/attachment.html>
