[Qgis-user] Loading issues with project file in QGIS 2.4 (64 bit)
Nathan Woodrow
madmanwoo at gmail.com
Tue Jul 14 17:19:24 PDT 2015
My advice would be to get a copy of the data on the local drive for her
computer and try it that way to remove any network issues.
- Nathan
On Wed, Jul 15, 2015 at 10:17 AM, Johanna Botman <
Johanna.Botman at griffith.nsw.gov.au> wrote:
> All the layers come off the same server that holds all our GIS data. The
> GIS data is held on a MS SQL server and copies of that data are made into
> TAB and SHP files overnight. In this case, the user has her own mapped
> drive with her own copy of those files (I can be risk averse as well).
> I know that I haven't changed anything. It is hard to know who may have
> made changes and what changes they made.
> _______________
> Johanna Botman
> GIS / Assets Officer
> Griffith City Council
> Ph: 02 6962 8168
> [image: Inactive hide details for Nathan Woodrow ---15/07/2015 10:12:57
> AM---The other layers are coming off the network? If it's been]Nathan
> Woodrow ---15/07/2015 10:12:57 AM---The other layers are coming off the
> network? If it's been working fine something else has changed b
> From: Nathan Woodrow <madmanwoo at gmail.com>
> To: Johanna Botman <Johanna.Botman at griffith.nsw.gov.au>,
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Date: 15/07/2015 10:12 AM
> Subject: Re: [Qgis-user] Loading issues with project file in QGIS 2.4 (64
> bit)
> The other layers are coming off the network? If it's been working fine
> something else has changed by the sounds of it.
> - Nathan
> On Wed, Jul 15, 2015 at 10:06 AM, Johanna Botman <
> *Johanna.Botman at griffith.nsw.gov.au* <Johanna.Botman at griffith.nsw.gov.au>>
> wrote:
> Thanks for the quick response Nathan,
> I'm not sure if you are familiar with Dial Before You Dig. When a
> request is made for information about the underground assets in a
> particular area, our council is one of the organisations that are asked to
> respond. That request is emailed to us and contains a .gml file with the
> specified location details.
> In order to speed up the processing at our end, I set up a project
> file that accepts this gml file, we zoom to the layer, align that with the
> canvas and produce the pdf file that goes back to the initial requestor.
> It worked fine for at least the last year. The layers in the project
> file are not large. The largest is 13Mb, the smallest is a few kilobytes.
> There are 17 layers in the project. I have had a request to put aerial
> imagery under the maps, but have resisted that because of the size of the
> images.
> What else do you need to know?
> _______________
> Johanna Botman
> Ph: *02 6962 8168* <02%206962%208168>
> 09:24:18 AM---On Wed, Jul 15, 2015 at 9:13 AM, Johanna Botman < Johanna.]Nathan
> Woodrow ---15/07/2015 09:24:18 AM---On Wed, Jul 15, 2015 at 9:13 AM,
> Johanna Botman < *Johanna.Botman at griffith.nsw.gov.au*
> <Johanna.Botman at griffith.nsw.gov.au>> wrote:
> From: Nathan Woodrow <*madmanwoo at gmail.com* <madmanwoo at gmail.com>>
> To: Johanna Botman <*Johanna.Botman at griffith.nsw.gov.au*
> <Johanna.Botman at griffith.nsw.gov.au>>,
> Cc: qgis-user <*qgis-user at lists.osgeo.org* <qgis-user at lists.osgeo.org>>
> Date: 15/07/2015 09:24 AM
> (64 bit)
> but IT tell me it is the nature of open source software.
> Good thing your IT is wrong then hey :P
> I also suspect network if the files are large it will pull the whole
> thing over the network before it can open it. GML also isn't the most
> efficient format in the world so take that into consideration.
> What other layers are in the project? If you have lots of network
> layers it will try and read them when you load the new layer in order to
> refresh the map, remember each pan is going to read the files to get the
> data.
> We will need a bit more info on the project and files to help more.
> - Nathan
> This e-mail, together with any attachments, is for the exclusive and
> confidential use of the addressee(s). Confidentiality is not waived if you
> are not the intended recipient. Any other distribution, use of, or
> reproduction without prior written consent is strictly prohibited.
> Views expressed in this e-mail are those of the individual, except
> where specifically stated otherwise. If this e-mail has been sent to you in
> error, please delete the e-mail completely and immediately from your
> system. Although reasonable precautions are taken, Griffith City Council
> does not warrant or guarantee this message to be free of errors,
> interference, viruses or similar malicious code and does not accept
> liability for any consequences to the recipient opening or using this email
> or attachments.
> This email was scanned and cleared by MailMarshal, Sophos & Kaspersky
> AV
> Views expressed in this e-mail are those of the individual, except where
> or attachments.
> This email was scanned and cleared by MailMarshal, Sophos & Kaspersky AV
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150715/1f9df1c6/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150715/1f9df1c6/attachment.jpg>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150715/1f9df1c6/attachment.gif>
