[Qgis-user] Loading issues with project file in QGIS 2.4 (64 bit)
Johanna Botman Johanna.Botman at griffith.nsw.gov.au
Tue Jul 14 17:22:11 PDT 2015
I'll try that and report back
_______________
Johanna Botman
GIS / Assets Officer
Griffith City Council
Ph: 02 6962 8168
To:	Johanna Botman <Johanna.Botman at griffith.nsw.gov.au>,
Cc:	qgis-user <qgis-user at lists.osgeo.org>
Date:	15/07/2015 10:19 AM
Subject:	Re: [Qgis-user] Loading issues with project file in QGIS 2.4
            (64 bit)
My advice would be to get a copy of the data on the local drive for her
computer and try it that way to remove any network issues.
- Nathan
On Wed, Jul 15, 2015 at 10:17 AM, Johanna Botman <
Johanna.Botman at griffith.nsw.gov.au> wrote:
  All the layers come off the same server that holds all our GIS data. The
  GIS data is held on a MS SQL server and copies of that data are made into
  TAB and SHP files overnight. In this case, the user has her own mapped
  drive with her own copy of those files (I can be risk averse as well).
  I know that I haven't changed anything. It is hard to know who may have
  made changes and what changes they made.
  _______________
  Johanna Botman
  Ph: 02 6962 8168
  Inactive hide details for Nathan Woodrow ---15/07/2015 10:12:57 AM---The
  other layers are coming off the network?  If it's beenNathan Woodrow
  ---15/07/2015 10:12:57 AM---The other layers are coming off the network?
  If it's been working fine something else has changed b
  Date: 15/07/2015 10:12 AM
  Subject: Re: [Qgis-user] Loading issues with project file in QGIS 2.4 (64
  bit)
  The other layers are coming off the network?  If it's been working fine
  something else has changed by the sounds of it.
  - Nathan
  On Wed, Jul 15, 2015 at 10:06 AM, Johanna Botman <
        Thanks for the quick response Nathan,
        I'm not sure if you are familiar with Dial Before You Dig. When a
        request is made for information about the underground assets in a
        particular area, our council is one of the organisations that are
        asked to respond. That request is emailed to us and contains a .gml
        file with the specified location details.
        In order to speed up the processing at our end, I set up a project
        file that accepts this gml file, we zoom to the layer, align that
        with the canvas and produce the pdf file that goes back to the
        initial requestor.
        It worked fine for at least the last year. The layers in the
        project file are not large. The largest is 13Mb, the smallest is a
        few kilobytes. There are 17 layers in the project. I have had a
        request to put aerial imagery under the maps, but have resisted
        that because of the size of the images.
        What else do you need to know?
        _______________
        Johanna Botman
        Ph: 02 6962 8168
        Inactive hide details for Nathan Woodrow ---15/07/2015 09:24:18
        AM---On Wed, Jul 15, 2015 at 9:13 AM, Johanna Botman < Johanna.
        Nathan Woodrow ---15/07/2015 09:24:18 AM---On Wed, Jul 15, 2015 at
        9:13 AM, Johanna Botman < Johanna.Botman at griffith.nsw.gov.au>
        Date: 15/07/2015 09:24 AM
        2.4 (64 bit)
              but IT tell me it is the nature of open source software.
        Good thing your IT is wrong then hey :P
        I also suspect network if the files are large it will pull the
        whole thing over the network before it can open it. GML also isn't
        the most efficient format in the world so take that into
        consideration.
        What other layers are in the project?  If you have lots of network
        layers it will try and read them when you load the new layer in
        order to refresh the map, remember each pan is going to read the
        files to get the data.
        We will need a bit more info on the project and files to help more.
        - Nathan
        This e-mail, together with any attachments, is for the exclusive
        and confidential use of the addressee(s). Confidentiality is not
        waived if you are not the intended recipient. Any other
        distribution, use of, or reproduction without prior written consent
        is strictly prohibited.
        Views expressed in this e-mail are those of the individual, except
        where specifically stated otherwise. If this e-mail has been sent
        to you in error, please delete the e-mail completely and
        immediately from your system. Although reasonable precautions are
        taken, Griffith City Council does not warrant or guarantee this
        message to be free of errors, interference, viruses or similar
        malicious code and does not accept liability for any consequences
        to the recipient opening or using this email or attachments.
        This email was scanned and cleared by MailMarshal, Sophos &
        Kaspersky AV
  This e-mail, together with any attachments, is for the exclusive and
  confidential use of the addressee(s). Confidentiality is not waived if
  you are not the intended recipient. Any other distribution, use of, or
  reproduction without prior written consent is strictly prohibited.
  Views expressed in this e-mail are those of the individual, except where
  specifically stated otherwise. If this e-mail has been sent to you in
  error, please delete the e-mail completely and immediately from your
  system. Although reasonable precautions are taken, Griffith City Council
  does not warrant or guarantee this message to be free of errors,
  interference, viruses or similar malicious code and does not accept
  liability for any consequences to the recipient opening or using this
  This email was scanned and cleared by MailMarshal, Sophos & Kaspersky AV
Please consider the environment before printing this email notice.
or reproduction without prior written consent is strictly prohibited.
where specifically stated otherwise. If this e-mail has been sent to
you in error, please delete the e-mail completely and immediately from
your system. Although reasonable precautions are taken, Griffith City
Council does not warrant or guarantee this message to be free of errors,
This email was scanned and cleared by MailMarshal, Sophos and Kaspersky AV
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150715/9111879a/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150715/9111879a/attachment.gif>
