[Qgis-user] QGIS Error
William Kyngesburye
woklist at kyngchaos.com
Sat Jul 18 11:54:28 PDT 2015
You need to install the latest GDAL Complete (which has a newer PROJ). The QGIS installer is just checking the major version of PROJ, I need to add a finer version check.
On Jul 18, 2015, at 4:48 AM, Richard Mwangi <richiemwesh at gmail.com> wrote:
> I am using os x yosemite and when i install qgis 2.8.2 it gives me the following error. Please help. Richard.
> Process: QGIS [9053]
> Path: /Applications/QGIS.app/Contents/MacOS/QGIS
> Identifier: org.qgis.qgis2
> Version: ???
> Code Type: X86-64 (Native)
> Parent Process: ??? [1]
> Responsible: QGIS [9053]
> User ID: 501
> Date/Time: 2015-07-18 11:39:33.688 +0300
> OS Version: Mac OS X 10.10.4 (14E46)
> Report Version: 11
> Anonymous UUID: D3CCFEE4-9B49-8517-42A1-7A64A170A5F0
> Time Awake Since Boot: 1900 seconds
> Crashed Thread: 0
> Exception Type: EXC_BREAKPOINT (SIGTRAP)
> Exception Codes: 0x0000000000000002, 0x0000000000000000
> Application Specific Information:
> dyld: launch, loading dependent libraries
> Dyld Error Message:
> Library not loaded: /Library/Frameworks/PROJ.framework/Versions/4/PROJ
> Referenced from: /Applications/QGIS.app/Contents/MacOS/QGIS
> Reason: Incompatible library version: QGIS requires version 10.0.0 or later, but PROJ provides version 8.0.0
> Binary Images:
> 0x7fff66f2f000 - 0x7fff66f65837 dyld (353.2.1) <72A99D0F-0B56-3938-ABC5-67A0F33757C4> /usr/lib/dyld
> 0x7fff88c44000 - 0x7fff88fdcff7 com.apple.CoreFoundation (6.9 - 1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
> 0x7fff91802000 - 0x7fff91802fff com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
> 0x7fff9429a000 - 0x7fff9430cfff com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
> Model: MacBookPro11,3, BootROM MBP112.0138.B15, 4 processors, Intel Core i7, 2.3 GHz, 16 GB, SMC 2.19f12
> Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
> Graphics: NVIDIA GeForce GT 750M, NVIDIA GeForce GT 750M, PCIe, 2048 MB
> Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
> Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
> AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.15.166.24.3)
> Bluetooth: Version 4.3.5f8 15969, 3 services, 27 devices, 1 incoming serial ports
> Network Service: Wi-Fi, AirPort, en0
> Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
> USB Device: Internal Memory Card Reader
> USB Device: BRCM20702 Hub
> USB Device: Bluetooth USB Host Controller
> USB Device: Apple Internal Keyboard / Trackpad
> Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
