[Qgis-user] Fwd: NTv2 plugin not visible
    Werner Macho
    werner.macho at gmail.com
    Mon Jul 20 21:54:17 PDT 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Zoran!
Did you take a look if you have activated the Processing tools?
Menu->
Processing -> Options -> Providers -> NTV2 Datum Transformations ->
Activate
Probably a update of the tools triggered a reset of the processing
settings for it.
And probably switch to the "Advanced interface" at the bottom of the
processing toolbox to see your loaded providers.
kind regards
Werner
On 20/07/15 22:54, Zoran Janković wrote:
> No, Processing plugin was an upgrade, and I've tried reinstalling
> it as well. NTv2 plugin was a new install, and reinstall (multiple
> times). Where is NTv2 plugin positioned in Processing Toolbox
> anyway, when it does appear?
> All other plugins work fine, I do not really use that many of
> them.
> Thanks,
> ______________________________________________________________________
__
>  Zoran
> On Sun, Jul 19, 2015 at 3:43 PM, Nicolas Cadieux
> <nicolas.cadieux at archeotec.ca> wrote:
>> OK, Not sure what to do... both where upgrades? Have you tried
>> reinstalling just the NTv2 plugin? The NTv2 datum plugin is for
>> the processing toolbox so I may be that it needs reinstalling.
>> Did you loose other plugins during the upgrade?
>> https://plugins.qgis.org/plugins/ntv2_transformations/
>> Nicolas Cadieux M.Sc. Les Entreprises Archéotec inc. 8548, rue
>> Saint-Denis Montréal H2P 2H2 Téléphone: 514.381.5112  Fax:
>> 514.381.4995 www.archeotec.ca
>> On Jul 19, 2015 09:16, "Zoran Janković [via OSGeo.org] " <[hidden
>> email]> wrote:
>> Hmmm, I did that - no effect. I can see the processing toolbox,
>> just no NTv2... The same thing happens on a second computer as
>> well - similar configuration (Win 8.1, 64 bit, QGIS 2.10...)
___
Zoran
>> On Sat, Jul 18, 2015 at 5:19 PM, Nicolas Cadieux <<a
>> href="/user/SendEmail.jtp?type=node&node=5216149&i
1;0">[hidden
email]> wrote:
>>> Hi, I am not on 2.10 yet and i am far from a windows box but If
>>> the plugin is unavailable try reinstalling the processing
>>> plugin.  In the past, the upgrade of QGIS can sometimes miss
>>> the processing plugin update especially when done from an other
>>> user (like admin) under Windows.
>>> On Jul 18, 2015 10:56, "Zoran Janković [via OSGeo.org] "
>>> <[hidden email]> wrote:
>>> Hi all,
>>> I was trying to use NTv2 plugin on QGIS 2.10, Windows 8.1,
>>> 64-bit. Plugin installs just fine, no errors, but it is not
>>> accessible in Processing Toolbox - not there at all. Is it
>>> hiding somewhere? Or am I getting blind, as well as stupid,
>>> over the years... :-) Search doesn't find it. QGIS is installed
>>> through OSGEO4W, otherwise working perfectly... I've tried with
>>> 2.11, same result, no NTv2 plugin...
>>> Any help would be greatly appreciated!
>>> BR,
____
Zoran
>>> _______________________________________________ Qgis-user
>>> mailing list <a
>>> href="/user/SendEmail.jtp?type=node&node=5216112&i&#
61;0">[hidden
email]
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> ________________________________ If you reply to this email,
>>> your message will be added to the discussion below:
>>> http://osgeo-org.1560.x6.nabble.com/NTv2-plugin-not-visible-tp521611
2.html
To start a new topic under Quantum GIS - User, email
>>> <a
>>> href="/user/SendEmail.jtp?type=node&node=5216149&i&#
61;1">[hidden
email]
>>> To unsubscribe from Quantum GIS - User, <a href="<a
>>> href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?m
acro=unsubscribe_by_code&node=4125267&code=bmljb2xhc
y5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">http://
osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscr
ibe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2
hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
here.
>>> <a href="<a
acro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&
base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.
NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&#
61;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aem
ail.naml-send_instant_email%21nabble%3Aemail.naml">http://osgeo-org.1560
.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id
1;instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces
.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web
.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%
3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21n
abble%3Aemail.naml"
style="font:9px serif">NAML
>>> ________________________________ View this message in context:
>>> Re: NTv2 plugin not visible Sent from the Quantum GIS - User
>>> mailing list archive at Nabble.com.
>>> mailing list <a
61;2">[hidden
email]
>> _______________________________________________ Qgis-user mailing
>> list <a
1;3">[hidden
email]
>> ________________________________ If you reply to this email, your
>> http://osgeo-org.1560.x6.nabble.com/NTv2-plugin-not-visible-tp5216112
p5216149.html
>> ml-node+s1560n4125267h38 at n6.nabble.com To unsubscribe from
>> href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?ma
cro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy
5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
here.
>> <a
cro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&b
ase=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.N
1;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aema
>> Re: Fwd: NTv2 plugin not visible Sent from the Quantum GIS - User
>> list Qgis-user at lists.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iEYEARECAAYFAlWt0HkACgkQDAH1YiCxBgmN2gCfaVyYpYvZciBLwASXI6p256zX
X3EAn1TwJ9D6WKzdE+dAUR5Fg3qjEWkA
=ODfO
-----END PGP SIGNATURE-----
