[Qgis-user] Small maths problem!
Richard McDonnell richard.mcdonnell at opw.ie
Thu Jul 23 01:10:41 PDT 2015
I am in need of some guidance, I am trying to create an "active
hatch/Fill" as part of a style im working on. What I want is for a hatch
to rotate depending on the orientation of a Polygon.
For example, here is the same entity rotated, with the hatch rotating.
The issue is I am working on a database, onto which I cant add any data
(additional columns) to the tables, I would like to do this from within
the styling.
You can use an expression to denote the angle, so I was hoping to do it
that way.
I was looking to utilize the geometry of a bounding box, and calculate
the angle of the diagonal, using something like
180*atan((ymax - ymin)/(xmax - xmin))/$pi + 90
But I am not having any luck....If there is no way at present to do
this, Might I put it forward as a possible new feature?
Regards,
Richard.
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/5be95570/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/5be95570/attachment.png>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/5be95570/attachment.vcf>
