[Qgis-user] problem scaling labels in Qgis 2.10
    Donovan Cameron
    sault.don at gmail.com
    Thu Jul 23 09:46:24 PDT 2015
You can set the label size to map units (ie, metres) instead of font pt.
That should help with scaling.
Donovan
On 23/07/15 09:31 AM, Richard McDonnell wrote:
> Try viewing the data in the canvas in the same scale as you wish to
> view it in the composer, you may also try to use data defined label
> placing, for the troublesome ones.
> Regards,
> Richard.
> On 23/07/2015 11:58, Rachel Brouwer wrote:
>> I'm currently using Ubuntu - QGis 2.10.0 Pisa.
>> When using the print Composer I have discovered my labels (size 8)
>> are all of sudden a whole lot bigger and for this reason overlapping.
>> How can I make sure that the size stays the same after going into the
>> print composer?
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
> OPW - Looking to the future - Caring for the past
> <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
Kind regards,
Donovan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/8ea293e5/attachment.html>
