[Qgis-user] QGIS 2.10 with / without GRASS 6.4.3
Chris Buckmaster
chris.buckmaster at runnymede.gov.uk
Fri Jul 24 00:14:27 PDT 2015
I am on Windows Vista 64 bit - I downloaded the windows 64 bit installer file from qgis.org
Chris
-----Original Message-----
From: Radim Blazek [mailto:radim.blazek at gmail.com]
Sent: 23 July 2015 20:06
To: Chris Buckmaster
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS 2.10 with / without GRASS 6.4.3
On Thu, Jul 23, 2015 at 1:33 PM, Chris Buckmaster <chris.buckmaster at runnymede.gov.uk> wrote:
> Hi there
> I have installed the new version of QGIS but notice it now comes with
> two different desktop applications; one with and one without GRASS 6.4.3.
> Is there any reason for this and should I be using each of them
> depending on what I am wanting to carry out? Just a bit confused with which one to use.
Which platform, which package? If it is from OSGeo4W, there are two batch files (the QGIS application is the same) which start QGIS either with GRASS 6 or GRASS 7 (you have to manually select GRASS 7 package in OSGeo4W setup if you want to use QGIS with GRASS 7 provider).
Radim
> Thanks
> Qgis-user mailing list
