[Qgis-user] QGis & GMesh
Werner Macho
werner.macho at gmail.com
Fri Jul 24 03:14:56 PDT 2015
Hi!
I am pretty sure you already know about the crayfish plugin for QGIS
.. which tries to do exactly these things for hydrodynamic modelling.
The first thing is - do you need that mesh as a shape or do you want
to render results?
Second thing - I am quite sure it is possible to implement loading of
these msh files either inside crayfish or through a plugin.
I suggest you to get in contact with the crayfish developers
(lutraconsulting - http://www.lutraconsulting.co.uk/) and ask if and
how it would be possible to implement loading this mesh.
kind regards
Werner
On Fri, Jul 24, 2015 at 11:23 AM, <francesco.maicu at ve.ismar.cnr.it> wrote:
> Dear Users,
> I use Gmsh (GMesh, automatic mesh generator) to draw a triangular finite
> element mesh to be used by a 2 or 3D hydrodinamic model (shallow water
> equation model).
> Gmsh write the mesh in differrent formats, most of them to be loaded in 3D
> CAD modeller (mechanical usage).
> The simplest format is a text file (.msh) easly understandable, basicly the
> list of nodes in the first part of the file, then the list of elements, each
> of them with the 3 nodes.
> I wonder if anyone has suggestions how to import in QGis this file, or if
> there is a tool for this porpouse.
> Thanks a lot everyone.
> best Regard
> Francesco
> Francesco Maicu
> ISMAR - CNR
> Arsenale Tesa 104 - CASTELLO 2737/E
> 30122 Venezia
> Italy
> tel. +39 041 2407944
> fax +39 041 5207940
> e-mail: francesco.maicu at ve.ismar.cnr.it
> skype: checcomex
> Qgis-user mailing list
