[Qgis-user] Blank square appears when using basemap
Susan Iremonger
s.iremonger at gmail.com
Sat Jul 25 03:05:01 PDT 2015
Hi David,
Thanks for your response. The link you sent was very interesting because I
am also getting that shift problem, but that is not the current problem (so
many problems!). With my current problem it isn't that the basemaps appear
shifted out of alignment but that a white square appears somewhere in m
view. Thanks very much for your input though, it was interesting to see
what "work arounds" people have come up with for the shift problem.
All the best.
--Susan.
On Fri, Jul 24, 2015 at 8:56 PM, David Fawcett <david.fawcett at gmail.com>
wrote:
> This is a pretty well known issue: http://hub.qgis.org/issues/5827
> On Fri, Jul 24, 2015 at 2:48 PM, Bernd Vogelgesang <
> bernd.vogelgesang at gmx.de> wrote:
>> Hi,
>> Looks to me like the tiles from bing are not loaded during print time.
>> I remember that fumbling in the settings->options->network made a
>> difference with this kind of problems in the past.
>> Not sure at all, but increase the value for time out (just add a zero)
>> and also increase the max retry ... value.
>> Maybe also increase the cache size (add zero) , but I'm not sure att all
>> if those services are influenced by these values anyway.
>> Others with better insight, please correct me.
>> Cheers
>> Bernd
>> Am 24.07.2015, 20:24 Uhr, schrieb Susan Iremonger <s.iremonger at gmail.com
>> Hi All,
>> I keep getting an annoying (and time-consuming!) white square appearing
>> in my map view when I use a basemap. I can get it to go away, generally, by
>> changing the scale of view or turning items on and off in the table of
>> contents, but it often just reappears and won't go away. Does anyone else
>> have this problem, and have you cracked it?
>> I attach a screenclip of the problem.
>> Thanks a mil.
>> Susan
>> Bernd Vogelgesang
>> Siedlerstraße 2
>> 91083 Baiersdorf/Igelsdorf
>> Tel: 09133-825374
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Cara Cottage
Pound road
Carrabaun
Westport
Co. Mayo
Ireland
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150725/e38298d9/attachment.html>
