[Qgis-user] Georeference'd maps off by 200m
Nick Papadonis
npapadonis at gmail.com
Mon Jul 27 15:50:34 PDT 2015
I was able to get everything to line up correctly by changing the layer property CRS from WGS84 UTM to EPSG:26718 NAD27 UTM. I was expecting the new raster to have WGS84 coordinates and the projected image with it. It seems the coordinates are still referencing the NAD27 projection after the they should not. Therefore I’m wondering if the Georeferencer pluging reprojects or not.
Thanks
> On Jul 27, 2015, at 6:19 PM, Nick Papadonis <npapadonis at gmail.com> wrote:
> Hi Folks,
> I’m trying to scan in a topographic map into a georeferenced raster so I can trace vector over it. I have been playing with the plugin for a few hours and am having odd results. I’m hoping an expert here can point me in the right direction. The issue is when I finally open the resulting TIFF file as a raster layer it appears the raster is 200m too far to the south. It also appears this is a uniform error across the map. The east and west line up fairly well. I was suspecting something with the projection choices or coordinate systems. I figured the coordinate system translation code would have already had plenty of use in the community by now. When creating the TIFF I used 10 coordinate points and Projective/Cubic. I also tried 2-degree poly with similar results. For the target SRS I used EPSG:32618 WGS84 UTM. The raster source is EPSG:2032 NAD27 UTM Zone 18N. The two vector data sources I checked agree and are EPSG:4326 WGS 84. I tried to create the TIFF in this format, however it ended up in the wrong coordinates when loaded as a layer.
> Any tips or tricks appreciated.
> Thanks,
> Nick
