[Qgis-user] Raster display options, color rendering, blending mode
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Jul 28 20:12:02 PDT 2015
You probably don't have a no data value in your raster. If that no data value is "0" or worst, -32768 then that value will be use to render the image.
You can temporally manually add a no data value in the layer properties. Then, that value will become transparent. If you what to add it permanently to the raster, you can use gdal warp, or add it in the "save raster" menu.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jul 28, 2015 20:30, "Matt Boyd [via OSGeo.org]" <ml-node+s1560n5217462h83 at n6.nabble.com> wrote:
Hi QGISers, I was getting some odd results when adjusting this option. It took me a little while to realise that the background color was being used in the rendering process. This is something I can work around until I need to use a black background. Is there a way to make the background color not interact with any visible layers? Thanks Matt
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Raster-display-options-color-rendering-blending-mode-tp5217462.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Raster-display-options-color-rendering-blending-mode-tp5217462p5217465.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150728/c3c681c0/attachment.html>
