[Qgis-user] Slow to open huge rasters
Donald, Nigel
Nigel.Donald at doeni.gov.uk
Thu Jul 30 07:16:08 PDT 2015
If the problem persists try creating virtual rasters [.vrt], can speed loading times quite significantly: go to Raster - Miscellaneous - Build Virtual Raster (catalog)
Nigel
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
Sent: 30 July 2015 15:01
To: Radim Blazek
Cc: qgis-user
Subject: Re: [Qgis-user] Slow to open huge rasters
Hi Radim.
thx for hint.
You have right.
And the trouble i spartially resolved.
The lock initial of qgis was due to the
create raster icons.
Infact removing it.
The layer is added without any trouble to the canvas.
I say partally resolved because nw qgis is no more lockd when add the raster t the canvas.
But is will start the think (without locking now) for show the raster.
And I guess it could take many times again.
Yes, the raster is on local harddisk.
I enable the debug.
A.
2015-07-30 13:54 GMT+02:00 Radim Blazek <radim.blazek at gmail.com>:
> On Thu, Jul 30, 2015 at 11:36 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi Radim,
>> thx for hint.
>> I try to set the contrast enhancement to NO STRETCH and Limits to
>> minimum / maximum , Apparently seem to have no result. The qgis is
>> locked in opening of raster, but of course I should wait for some
>> hours to see if some improvements is occursed.
> You can try to uncheck Options > Canvas & Legend > Layer Legend >
> Create raster icons but I don't think that it could help if zoom/pan
> is fast, so it seems that there are overviews (pyramids). In fact,
> even with cumulative cut it should not be slow if there are overviews
> because default cut calculation is using estimated histogram (250000
> pixels).
> The file is on local hard disk?
> Do you see what is happening from debug output?
> If you save a project with the raster, the next load of the project is fast?
> Radim
>> A.
>> 2015-07-30 9:52 GMT+02:00 Radim Blazek <radim.blazek at gmail.com>:
>>> On Thu, Jul 30, 2015 at 9:19 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>> Hi,
>>>> I have a GeoTiff raster of 24Gbyte, floating point (Float64) with
>>>> 11 bands and fomat geotiff.
>>>> When try to open it with qgis 2.8.1 I see it take a really uge time
>>>> to open it (about 10 hours).
>>>> Initially I guess that was a time due to the huge dimension, but
>>>> after the qgis show it.
>>>> I notice that it is reallyquickly to zoom and pan.
>>>> I don't understand why this difference between the open time and zoom/pan time.
>>>> My first suspect was that qgis want to calculate the statistics in first open.
>>>> But after a check with gdalinfo I see the statistics are available
>>>> also in original tiff.
>>> QGIS defaults are stretch to 2/98% cut, try to set in Options >
>>> Rendering > Rasters Contrast enhancement: No stretch or Limits:
>>> Minimum / maximum
>>> Radim
>>>> So I dont know really why it take so more time to open it.
>>>> I hope to find some setting to reduce the pen time for this kind of images.
>>>> Thx,
>>>> A.
>>>> Andrea Peri
>>>> qwerty àèìòù
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Andrea Peri
>> qwerty àèìòù
Andrea Peri
qwerty àèìòù
