[Qgis-user] different QGIS behavior between windows and lubuntu
Fernando M. Roxo da Motta petro at roxo.org
Tue Jun 2 17:56:43 PDT 2015
On Sun, 31 May 2015 14:23:13 +0200, Giacomo Fontanelli
<giacomofontanelli76 at gmail.com> wrote:
> Dear folks
> Fernando was right.
> as I lounch   LC_ALL=C  qgis
> I find a correct result.
> Now I have to find the way to set point as decimal separator on my OS
> set with Italian settings.
  Sorry for the long delay.
  There are a number of options, I think that the worse of all is block
the i18n (internationalization) and l10n (localization) in your
computer.
  You can just for qgis alter the driver script (/usr/bin/qgis in my
machine) and inser a line :
export LC_ALL=C
But this would cripple your qgis for Italian language.
  I would suggest you to try first to call qgis as:
  LC_NUMERIC=en_US.UTF-8  qgis
  If it results, you can change the drive script inserting a line:
export LC_NUMERIC=en_US.UTF-8
in some place at the start of the script.
  If you use a launcher somewhere, for example an icon in desktop or on
a panel, you can customise it changing the the launch command, as
above, to:
bash -c "LC_NUMERIC=en_US.UTF-8 /usr/bin/qgis %F"
  Hope this helps.
> Thanx
> On Sun, May 31, 2015 at 2:19 PM, Giacomo Fontanelli <
> > Dear Fernando it works
> > Now the question is: How can set the point as decimal separator as
> > default on my PC?
> > Thank you very much
> > Giacomo
> > On Fri, May 29, 2015 at 11:16 PM, Fernando M. Roxo da Motta <
> > petro at roxo.org> wrote:
> >> On Fri, 29 May 2015 16:42:15 -0300, George Silva
> >> <georger.silva at gmail.com> wrote:
> >> > No this is not a localization problem. I just tested this.
> >> > Raster calculator makes expressions with ',' invalid. At least,
> >> > on my machine (Mint 14)
> >> > This is the output of my locales:
> >>   Pretty much like mine, except that I don't have any
> >> "en_US.UTF-8".  ;)
> >> > LANG=en_US.UTF-8
> >> > LANGUAGE=
> >> > LC_CTYPE="en_US.UTF-8"
> >> > LC_NUMERIC=pt_BR.UTF-8
> >> > LC_TIME="en_US.UTF-8"
> >> > LC_COLLATE="en_US.UTF-8"
> >> > LC_MONETARY=pt_BR.UTF-8
> >> > LC_MESSAGES="en_US.UTF-8"
> >> > LC_PAPER=pt_BR.UTF-8
> >> > LC_NAME=pt_BR.UTF-8
> >> > LC_ADDRESS=pt_BR.UTF-8
> >> > LC_TELEPHONE=pt_BR.UTF-8
> >> > LC_MEASUREMENT=pt_BR.UTF-8
> >> > LC_IDENTIFICATION=pt_BR.UTF-8
> >> > LC_ALL=
> >> > I just retried this. Grabbed a raster with floating point values
> >> > and added 1.1 - the result is just an add by 1, without the 0.1.
> >> > Giovanni was right about this, something is truncating these
> >> > values in Raster Calculator to integers, and my input was 3.1,
> >> > and the output 4.1 (added just 1, instead of 1.1) when it should
> >> > be 4.2.
> >>   I still think it can have some relation with locale, perhaps in
> >> another sense.  I don't know if I will be able to explain myself
> >> here.
> >>   I have noticed some inconsistency in qgis on this aspect.  I
> >> already stumbled on at least one situation where the comma
> >> separator weren't accepted and I tried to divide by the inverse.
> >> It was with qgis 2.6 (I am using 2.8.2 in [Xu|U]buntu), at the
> >> time I was trying to convert the line length from meters to
> >> kilometres multiplying by 0.001, IIRC everything turned into
> >> zero.  After that, just in case, I tried to divide by 1000 and I
> >> got the amount of meters I expected.
> >>   There seems to exist some dark place between the keyboard (Qt?)
> >> and the code where the localization seems to be mixed up and
> >> completely screwed up.
> >>   If I can suggest a test to Giacomo and George, in your Linux
> >> installation open a terminal emulator (don't matter which one) and
> >> try to execute qgis the following way:
> >>   LC_ALL=C  qgis
> >> This should "remove" the localization support and work with dot as
> >> the decimal separator.   If it still gets the wrong result with the
> >> expression  "band at map" * 0.1, I think that the problem can be
> >> intrinsic to the code.   If it works correctly I think the problem
> >> is somewhat related to the interface with Qt.
> >>   I don't normally work with raster layers, but if you have a
> >> (very) small example with floating point attribute I can try it
> >> here.
> >>   Best regards.
> >> > George
> >> > On Fri, May 29, 2015 at 4:27 PM, Fernando M. Roxo da Motta
> >> > <petro at roxo.org> wrote:
> >> > > On Fri, 29 May 2015 10:20:05 +0200, Giacomo Fontanelli
> >> > > > I used to work with qgis 2.8.1 in Lubuntu and in windows7.
> >> > > > Each time I try to multiplicate a map for a number comprise
> >> > > > between 0 and 1 (i.e. 0.1) I get a good results on windows
> >> > > > OS, but I get a map with only 0 and NaN on Linux.
> >> > > > Further, I get a correct result on Lubuntu if I divide by 10
> >> > > > instead of multiplicate by 0.1.
> >> > >   It looks very much like a localization problem.  I guess
> >> > > that with this name you are using a platform with Italian
> >> > > language.   I think that the standard there is the same I have
> >> > > in Brazil, that is the decimal separator is comma (,) instead
> >> > > of dot (.).   Try to use:
> >> > >    "band at map" * 0,1
> >> > >   Hope this helps.
> >> > > > Conclusion
> >> > > > "band at map" * 0.1 on windows = OK "band at map" * 0.1 on lubuntu
> >> > > > = only 0 and NaN "band at map" / 10 on lubuntu = ok.
> >> > > > I use the same gdal version and I always get a correct
> >> > > > Float32 map.
> >> > > > Canyou help me?
> >> > > > Thanx
> >> > >   Roxo
> >> > > ---------------- Non luctari, ludare -------------------+
> >> > > WYSIWYG Fernando M. Roxo da Motta
> >> > > <petro at roxo.org>              | Editor? Except where
> >> > > explicitly stated I speak on my own behalf.|  VI !! ( Usuário
> >> > > Linux registrado #39505 )               | I see text,
> >> > > ------------ Quis custodiet ipsos custodes?-------------+ I
> >> > > get text!
> >> > > _______________________________________________
> >> > > Qgis-user mailing list
> >> > > Qgis-user at lists.osgeo.org
> >> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>   Roxo
> >> ---------------- Non luctari, ludare -------------------+ WYSIWYG
> >> Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
> >> Except where explicitly stated I speak on my own behalf.|  VI !!
> >>       ( Usuário Linux registrado #39505 )               | I see
> >> text, ------------ Quis custodiet ipsos custodes?-------------+ I
> >> get text!
  Roxo
      ( Usuário Linux registrado #39505 )               | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
