[Qgis-user] Logical or boolean column
CHind at bayside.vic.gov.au
Tue Jun 2 18:44:14 PDT 2015
Hi
I would like to add a new column to a linked MS SQL table within QGIS via
the Layer Properties, Fields, Add column.
I am not sure what option to use within the Type to select as I only want
to retain boolean values or either 0 or 1, Y or N, or T or F.
What is the best practice here?
Kind Regards
Chrissie Hind
Senior GIS Analyst
Bayside City Council
T: 03 9599 4792
F: 03 9598 4474
M: 0409 938 697
Email: Chind at bayside.vic.gov.au
Web: www.bayside.vic.gov.au****************************************************************************** "Please consider the environment before you print this email." This email, including all attachments, is confidential. Any personal or sensitive information contained in this email and attachments must be handled in accordance with the Victorian Information Privacy Act 2000 and the Health Records Act 2001. If you are not the intended recipient, you must not disclose, distribute, copy or use the information contained in this email or attachments. Any confidentiality or privilege is not waived or lost because this email has been sent to you in error. If you have received it in error, please advise the sender by return email, delete it from your system and destroy any copies. The sender gives no warranty that any attachments to this email are free from viruses or other defects. ********************************************************************************
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150603/85586c7b/attachment.html>
