[Qgis-user] Logical or boolean column
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed Jun 3 05:31:44 PDT 2015
If I understand, your boolean values are in the MS SQL table?  Then you will need a field with unique values (integers are simpler) in both the QGIS table and the external table in order to link both tables.  If you can't use integers, you could use another type but this field needs to be unique (therefore if you use a family name, you are likely to have two identical names.)
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Jun 2, 2015 9:56 PM, "CHind [via OSGeo.org]" <ml-node+s1560n5208788h89 at n6.nabble.com> wrote:
	Hi I would like to add a new column to a linked MS SQL table within QGIS via the Layer Properties, Fields, Add column. I am not sure what option to use within the Type to select as I only want to retain boolean values or either 0 or 1,  Y or N, or T or F. What is the best practice here? Kind Regards Chrissie Hind Senior GIS Analyst Bayside City Council
T:  03 9599 4792 F:  03 9598 4474 M:  0409 938 697 Email:     [hidden email] Web:      www.bayside.vic.gov.au ******************************************************************************
"Please consider the environment before you print this email."
 This email, including all attachments, is confidential. Any personal or
 sensitive information contained in this email and attachments must be
 handled in accordance with the Victorian Information Privacy Act 2000 and
 the Health Records Act 2001. If you are not the intended recipient, you
 must not disclose, distribute, copy or use the information contained in
 this email or attachments.  Any confidentiality or privilege is not waived
 or lost because this email has been sent to you in error.  If you have
 received it in error, please advise the sender by return email, delete it
 from your system and destroy any copies. The sender gives no warranty that
 any attachments to this email are free from viruses or other defects.
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Logical-or-boolean-column-tp5208788.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Logical-or-boolean-column-tp5208788p5208891.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150603/2ac80ad7/attachment.html>
