[Qgis-user] SAGA Mac OSX in QGIS 2.8.2
William Kyngesburye woklist at kyngchaos.com
Wed Jun 3 06:44:19 PDT 2015
As the error suggests, check the log (processing log) for more details on why it failed.  Look in the INFO section for SAGA command output.
On Jun 2, 2015, at 3:22 AM, Olav Peeters <opeeters at gmail.com> wrote:
> Hi,
> I'm having issues with the SAGA modules in Qgis 2.8.2. Performing an analysis ends with:
> Oooops! The following output layers could not be open
> Grid: /var/folders/g4/__hdq_jj7fb095y56hsbprzh0000gn/T/processing/e60cad6f141643fa9d38f85fc7e74aef/USERGRID.tif
> The above files could not be opened, which probably indicates that they were not correctly produced by the executed algorithm
> Checking the log information might help you see why those layers were not created as expected
> According to the readme (dmg from http://www.kyngchaos.com/software/qgis) I should temporarily move all files in:
> /Library/Application Support/GDAL/1.11/PlugIns
> to elsewhere or rename the PlugIns directory. But this directory is empty.
> I did install the recent GDAL 1.11 Complete [39.3 MiB] 2015-5-18 from:
> http://www.kyngchaos.com/software/frameworks#gdal_complete
> The path as specified in the options of the processing plugin in QGIS is:
> /Applications/QGIS.app/Contents/MacOS/lib/saga/
> And indeed all SAGA modules are there..
> Does anyone have any pointers?
> I also tried uninstalling, deleting ~/.qgis2, deleting the plist's of QGIS, reinstalling both 2.8.1 and 2.8.2.. no luck.
> Cheers,
> Olav
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
