[Qgis-user] Mask for map in print composer?
Alexandre Neto senhor.neto at gmail.com
Fri Jun 5 06:37:49 PDT 2015
If you have a polygon layer with the desired shape, you can put it on topo
of all other layers and use the inverted polygon style.
On the other hand, you can also do that exporting the map to svg and do the
masking in inkscape.
Best regards,
Alexandre Neto
On Fri, Jun 5, 2015 at 2:29 PM, Joris Hintjens <jorishin at gmail.com> wrote:
> Hello there,
>  Is here a way of using a basic shape (ellips, triangle) to use as mask
> for a map in print composer?
> Did some googling without succes.
> final result should be something like this:
> http://www.canstockphoto.com/magnifying-glass-with-map-10063072.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150605/1bf45f57/attachment.html>
