[Qgis-user] Mask for map in print composer?
    Joris Hintjens
    jorishin at gmail.com
    Fri Jun  5 08:58:24 PDT 2015
Thanks Alexandro. Didn’t see that one before. exactly what I need.
Joris
> Op 5-jun.-2015, om 15:37 heeft Alexandre Neto <senhor.neto at gmail.com> het volgende geschreven:
> Hi,
> If you have a polygon layer with the desired shape, you can put it on topo of all other layers and use the inverted polygon style.
> On the other hand, you can also do that exporting the map to svg and do the masking in inkscape.
> Best regards,
> Alexandre Neto
> On Fri, Jun 5, 2015 at 2:29 PM, Joris Hintjens <jorishin at gmail.com <mailto:jorishin at gmail.com>> wrote:
> Hello there,
>  Is here a way of using a basic shape (ellips, triangle) to use as mask for a map in print composer?
> Did some googling without succes.
> final result should be something like this:
> http://www.canstockphoto.com/magnifying-glass-with-map-10063072.html <http://www.canstockphoto.com/magnifying-glass-with-map-10063072.html>
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150605/c540e310/attachment.html>
