[Qgis-user] Loading OS Mastermap Data into QGIS
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Fri Jun 5 09:22:38 PDT 2015
Hi Martin,
OS Translator II can load your files. But you need to install and configure a PostGIS connection:
http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_tut01
Once PostGIS is installed, you need to create a connection to your database in QGIS. OS Translator II can be then used to load all your data into PostGIS:
http://www.lutraconsulting.co.uk/blog/2015/02/23/loading-mastermap-free-easy-fast/
Hope that helps.
Cheers,
Saber
Saber Razmjooei
Lutra Consulting
<http://www.lutraconsulting.co.uk/> www.lutraconsulting.co.uk
Tel: +44 (0)1444 848012
Mob: +44 (0)7568 129733
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Martin Sullivan
Sent: 05 June 2015 17:06
To: QGIS-user at lists.osgeo.org
Subject: [Qgis-user] Loading OS Mastermap Data into QGIS
OS Masterdata. ITN files in the format .gz
I am struggling, as a new user to load all of these files into QGIS 2.8.
I can load files one at a time (or select all the files in a sub-folder), each time getting a new window asking which vector layers to add (Road, RoadLink, RoadNode - which appear to be all that any of the files contain) and then having to hit Select All and OK. Each one of these then creates a new layer.
I've searched the internet and found several solutions (so called) that say they can load OS data but I cannot find one that works. (add in OS Translator II, and a few other external programs that I have now lost track of).
Surely there is a way to load all these files without having to do Select All and OK, fo each single file, and to create one single layer?
Thanks for any help.
Martin Sullivan
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell pro
ducts, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150605/b3aa1aca/attachment.html>
