[Qgis-user] Loading OS Mastermap Data into QGIS
Martin Sullivan
martinsullivan4x4 at yahoo.co.uk
Mon Jun 8 03:05:37 PDT 2015
Thank you Saber,
I have installed the Postgresql, following you instructions as best I could. However when I open the addin in QGIS I am unable to change the Connection box, which while I was playing earlier I had entered 'Test'. I have tried un installing the add in shutting down and starting again - but I am still unable to change it from test.
I am very new to QGIS and struggling with these new concepts...
Screen print attached.
On Friday, 5 June 2015, 17:23, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk> wrote:
#yiv2402909844 #yiv2402909844 -- _filtered #yiv2402909844 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv2402909844 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #yiv2402909844 {font-family:Chalkboard;panose-1:0 0 0 0 0 0 0 0 0 0;}#yiv2402909844 #yiv2402909844 p.yiv2402909844MsoNormal, #yiv2402909844 li.yiv2402909844MsoNormal, #yiv2402909844 div.yiv2402909844MsoNormal {margin:0cm;margin-bottom:.0001pt;font-size:12.0pt;color:black;}#yiv2402909844 a:link, #yiv2402909844 span.yiv2402909844MsoHyperlink {color:blue;text-decoration:underline;}#yiv2402909844 a:visited, #yiv2402909844 span.yiv2402909844MsoHyperlinkFollowed {color:purple;text-decoration:underline;}#yiv2402909844 span.yiv2402909844EmailStyle17 {color:#1F497D;}#yiv2402909844 .yiv2402909844MsoChpDefault {font-size:10.0pt;} _filtered #yiv2402909844 {margin:72.0pt 72.0pt 72.0pt 72.0pt;}#yiv2402909844 div.yiv2402909844WordSection1 {}#yiv2402909844 Hi Martin, OS Translator II can load your files. But you need to install and configure a PostGIS connection:http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_tut01 Once PostGIS is installed, you need to create a connection to your database in QGIS. OS Translator II can be then used to load all your data into PostGIS:http://www.lutraconsulting.co.uk/blog/2015/02/23/loading-mastermap-free-easy-fast/ Hope that helps. Cheers,Saber Saber Razmjooei
Lutra Consulting
Tel: +44 (0)1444 848012
Mob: +44 (0)7568 129733 From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Martin Sullivan
Sent: 05 June 2015 17:06
To: QGIS-user at lists.osgeo.org
Subject: [Qgis-user] Loading OS Mastermap Data into QGIS OS Masterdata. ITN files in the format .gz
I am struggling, as a new user to load all of these files into QGIS 2.8.
I can load files one at a time (or select all the files in a sub-folder), each time getting a new window asking which vector layers to add (Road, RoadLink, RoadNode - which appear to be all that any of the files contain) and then having to hit Select All and OK. Each one of these then creates a new layer.
I've searched the internet and found several solutions (so called) that say they can load OS data but I cannot find one that works. (add in OS Translator II, and a few other external programs that I have now lost track of).
Surely there is a way to load all these files without having to do Select All and OK, fo each single file, and to create one single layer?
Thanks for any help.
Martin Sullivan
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out such checks as you feel appropriate.If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions shall apply unless explicitly stated otherwise.Saber Razmjooei and Peter Wells trading as Lutra Consulting.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150608/bca4397d/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150608/bca4397d/attachment.jpe>
