[Qgis-user] Question on PostGIS Table and QGIS
    Randal Hale
    rjhale at northrivergeographic.com
    Sun Jun  7 07:50:31 PDT 2015
I'm breaking new ground and I'm pretty sure this might be a mistake on
my end. I just need to understand why.
I've set up a PostGIS database. I'm importing data through DB manager
into my schema.
I imported some parcel records and discovered that I had multipolygons.
So I decided to break them up into single polygons through the psql
interface:
create table trgtgis.parcels as select *, (st_dump(geom)).geom as
the_geom from trgtgis.boundary;
When I go back to QGIS I have two tables called parcels (only one listed
if I look through postgresql). One table is what I suspect to see with
column called the_geom, data Type as Geometry, Spatial type of Polygon,
SRID of 26916. The second parcel table is greyed out and doesn't have a
spatial type or a SRID. Neither lists a primary key (I need to go back
and add one) but I don't think this is the problem...I think.
Screenshot:
https://drive.google.com/file/d/0B8WLtz606XDdcFIxaG5fNExpMlU/view?usp=sharing
Suggestions?
Randy
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale     http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
Southeast OSGEO: http://wiki.osgeo.org/wiki/Southeast_US
