[Qgis-user] Issues to install QGIS on RedHat 6
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Tue Jun 9 11:33:36 PDT 2015
I have issue to install QGIS 2.8 on Linux RedHat 6.
First part: I installed ELGIS and EPEL using the instructions from: http://www.qgis.org/en/site/forusers/alldownloads.html#rhel-centos-scientific-linux
The following commands were successfully executed
sudo wget fedora.vitu.ch/EL/qgis.repo -P /etc/yum.repos.d/
sudo rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
But the execution of the next one failed:
sudo yum update
I got this error:
http://fedora.vitu.ch/EL/6Workstation/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404"
Trying other mirror.
Error: Cannot retrieve repository metadata (repomd.xml) for repository: qgis. Please verify its path and try again
This command failed as well.
sudo yum install qgis qgis-python qgis-grass qgis-mapserver
It seems the issue has been reported on Apr 14 2014 but no solution was release. It seems the location http://fedora.vitu.ch/EL/6Workstation/x86_64/repodata/does not exist anymore or was changed and instructions were not updated.
Does anyone know a solution?
Thanks,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150609/c847e691/attachment.html>
