[Qgis-user] Issues to install QGIS on RedHat 6
Matthias Kuhn matthias.kuhn at gmx.ch
Wed Jun 10 00:45:35 PDT 2015
There was never a release for 6Workstation and the last release for
6Server was available for 2.0.1. I symlinked the 6Workstation now so you
should be able to install 2.0.1 from there - but that's probably not
what you need.
I am currently trying to create packages for 2.8.2. If it just works I
will make them available ASAP. I am not totally aware of the status of
all dependencies, so we will have to wait and see how much trouble there is.
Regards,
Matthias
On 06/09/2015 08:33 PM, Tudorache, Marian wrote:
> Hi,
> I have issue to install QGIS 2.8 on Linux RedHat 6.
> First part: I installed ELGIS and EPEL using the instructions from:
> http://www.qgis.org/en/site/forusers/alldownloads.html#rhel-centos-scientific-linux
> The following commands were successfully executed
> sudo wget fedora.vitu.ch/EL/qgis.repo -P /etc/yum.repos.d/
> sudo rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
> <http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu>
> But the execution of the next one failed:
> sudo yum update
> I got this error:
> http://fedora.vitu.ch/EL/6Workstation/x86_64/repodata/repomd.xml:
> [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404"
> Trying other mirror.
> Error: Cannot retrieve repository metadata (repomd.xml) for
> repository: qgis. Please verify its path and try again
> This command failed as well.
> sudo yum install qgis qgis-python qgis-grass qgis-mapserver
> It seems the issue has been reported on Apr 14 2014 but no solution
> was release. It seems the location
> http://fedora.vitu.ch/EL/6Workstation/x86_64/repodata/does not exist
> anymore or was changed and instructions were not updated.
> Does anyone know a solution?
> Thanks,
> Marian
> This electronic message, as well as any transmitted files included in
> the electronic message, may contain privileged or confidential
> information and is intended solely for the use of the individual(s) or
> entity to which it is addressed. If you have received this electronic
> message in error please notify the sender immediately and delete the
> electronic message. Any unauthorized copying, disclosure or
> distribution of the electronic message is strictly forbidden. NAV
> CANADA accepts no liability for any damage caused by any virus and/or
> other malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels
> destinés à l’usage exclusif des personnes ou des organismes à qui ils
> s’adressent. Si vous avez reçu ce message électronique par erreur,
> veuillez en informer l’expéditeur immédiatement et supprimez le. Toute
> reproduction, divulgation ou distribution du présent message
> électronique est strictement interdite. NAV CANADA n’assume aucune
> responsabilité en cas de dommage causé par tout virus ou autre
> programme malveillant transmis par ce message électronique.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150610/df2bfc58/attachment.html>
