[Qgis-user] Transferring Attributes
Randal Hale rjhale at northrivergeographic.com
Tue Jun 9 19:25:00 PDT 2015
Try Vector -> Data Management -> Join Attributes by Location. That
should allow you to transfer the elevation from your contour to the
polygon. Make sure your contour and polygon have the same projection.
Hope that helps.
Randy
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale     http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
On 06/09/2015 10:18 PM, Springfield Harrison wrote:
> Hello,
> I would like to transfer contour line elevation values to polygons in
> another shapefile based on the contours contained within any given
> polygon.  Is there a tool for this?
> I can select the polygons with a spatial query based upon another
> polygon but need to add the height info from the contour file.
>     Thank you, cheers . . . .   Springfield Harrison
> Qgis-user mailing list
