[Qgis-user] Transferring Attributes
    Springfield Harrison
    stellargps at gmail.com
    Tue Jun  9 23:42:32 PDT 2015
Hello Randy,
That worked very well, thanks.  The only change I'd make is to open a
list of fields to transfer as not all are needed, only 1 in my case.
         Great tool, thanks, cheers . . . .   Spring Harrison
At 09-06-2015 19:25 Tuesday, Randal Hale wrote:
>Try Vector -> Data Management -> Join Attributes by Location. That
>should allow you to transfer the elevation from your contour to the
>polygon. Make sure your contour and polygon have the same projection.
>Hope that helps.
>Randy
>Randal Hale
>North River Geographic Systems, Inc
>http://www.northrivergeographic.com
>423.653.3611 rjhale at northrivergeographic.com
>twitter:rjhale    http://about.me/rjhale
>http://www.northrivergeographic.com/introduction-to-quantum-gis
>On 06/09/2015 10:18 PM, Springfield Harrison wrote:
>>Hello,
>>I would like to transfer contour line elevation values to polygons
>>in another shapefile based on the contours contained within any
>>given polygon. Is there a tool for this?
>>I can select the polygons with a spatial query based upon another
>>polygon but need to add the height info from the contour file.
>>    Thank you, cheers . . . .  Springfield Harrison
>>_______________________________________________
>>Qgis-user mailing list
>>Qgis-user at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/qgis-user
