[Qgis-user] Transferring Attributes
    Randal Hale
    rjhale at northrivergeographic.com
    Wed Jun 10 03:29:39 PDT 2015
You can also pop open the Attribute table for your newly created data
(right click open attribute table), enable editing, and remove (Delete
Column) the extra fields if you wish.
Glad it worked for you,
Randy
On 06/10/2015 02:42 AM, Springfield Harrison wrote:
> Hello Randy,
> That worked very well, thanks.  The only change I'd make is to open a
> list of fields to transfer as not all are needed, only 1 in my case.
>         Great tool, thanks, cheers . . . .   Spring Harrison
> At 09-06-2015 19:25 Tuesday, Randal Hale wrote:
>> Try Vector -> Data Management -> Join Attributes by Location. That
>> should allow you to transfer the elevation from your contour to the
>> polygon. Make sure your contour and polygon have the same projection.
>> Hope that helps.
>> Randy
>> Randal Hale
>> North River Geographic Systems, Inc
>> http://www.northrivergeographic.com
>> 423.653.3611 rjhale at northrivergeographic.com
>> twitter:rjhale    http://about.me/rjhale
>> http://www.northrivergeographic.com/introduction-to-quantum-gis
>> On 06/09/2015 10:18 PM, Springfield Harrison wrote:
>>> Hello,
>>> I would like to transfer contour line elevation values to polygons
>>> in another shapefile based on the contours contained within any
>>> given polygon. Is there a tool for this?
>>> I can select the polygons with a spatial query based upon another
>>> polygon but need to add the height info from the contour file.
>>>    Thank you, cheers . . . .  Springfield Harrison
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
Southeast OSGEO: http://wiki.osgeo.org/wiki/Southeast_US
