[Qgis-user] Converting an OSM XML file to a SpatiaLite DB file
Lucas Bernard Grigri
lgrigri at uvm.edu
Wed Jun 10 11:22:13 PDT 2015
Hello,
I am using open street map, and downloaded the OpenStreetMap data
(with From Map Canvas as the Extent), to create an OSM XML file. I
then tried to convert this XML file to a SpatiaLite DB file by going
VECTOR-> OPENSTREETMAP-> IMPORT TOPOLOGY FROM XML. However, when I do
this I get an error which reads:
FAILED TO IMPORT OSM DATA:
XML ERROR: PREMATURE END OF DOCUMENT
Please let me know if you have experienced this same problem and how
to go about fixing it.
Thanks
Lucas
