[Qgis-user] Converting an OSM XML file to a SpatiaLite DB file
Cascafico Giovanni
cascafico at gmail.com
Wed Jun 10 13:26:48 PDT 2015
Using osm generated by overpass-turbo.eu queries (export raw) always worked
for me. Quick osm plugin works as well.
I grab this thread to ask one more question DB Manager related...
how can I clean up db manager connection list, once finished?
cascafico.altervista.org
twitter.com/cascafico
Il 10/giu/2015 20:22 "Lucas Bernard Grigri" <lgrigri at uvm.edu> ha scritto:
> Hello,
> I am using open street map, and downloaded the OpenStreetMap data (with
> From Map Canvas as the Extent), to create an OSM XML file. I then tried to
> convert this XML file to a SpatiaLite DB file by going VECTOR->
> OPENSTREETMAP-> IMPORT TOPOLOGY FROM XML. However, when I do this I get an
> error which reads:
> FAILED TO IMPORT OSM DATA:
> XML ERROR: PREMATURE END OF DOCUMENT
> Please let me know if you have experienced this same problem and how to go
> about fixing it.
> Thanks
> Lucas
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150610/4172ba3b/attachment.html>
