[Qgis-user] Converting an OSM XML file to a SpatiaLite DB file
Lucas Bernard Grigri lgrigri at uvm.edu
Wed Jun 10 14:53:56 PDT 2015
I have the quick osm plugin installed but it still won't work.
Quoting Cascafico Giovanni <cascafico at gmail.com>:
> Using osm generated by overpass-turbo.eu queries (export raw) always worked
> for me. Quick osm plugin works as well.
> I grab this thread to ask one more question DB Manager related...
> how can I clean up db manager connection list, once finished?
> cascafico.altervista.org
> twitter.com/cascafico
> Il 10/giu/2015 20:22 "Lucas Bernard Grigri" <lgrigri at uvm.edu> ha scritto:
>> Hello,
>> I am using open street map, and downloaded the OpenStreetMap data (with
>> From Map Canvas as the Extent), to create an OSM XML file. I then tried to
>> convert this XML file to a SpatiaLite DB file by going VECTOR->
>> OPENSTREETMAP-> IMPORT TOPOLOGY FROM XML. However, when I do this I get an
>> error which reads:
>>                FAILED TO IMPORT OSM DATA:
>>                XML ERROR: PREMATURE END OF DOCUMENT
>> Please let me know if you have experienced this same problem and how to go
>> about fixing it.
>> Thanks
>> Lucas
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
