[Qgis-user] Do I need satellite raster layers relative to an extended UTM zone?
ardi
ardillasdelmonte at gmail.com
Thu Jun 11 00:18:22 PDT 2015
Thanks a lot for your advice, Nicolas!
ardi
On Thu, Jun 11, 2015 at 1:09 AM, Nicolas Cadieux
<nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> It's never a good idea to delete files that you have reprojected.
> Reprojection will, in most cases slightly alter the data although that
> depends on the parameters used. You could always test by reprojecting the
> file back to the original projection and then by using raster math to see
> the differences, if any.
> If you want to save space, I suggest you compress the data using "deflate"
> parameters. (You need to manually add support for bigtiff if the file is
> over 4GB. ) Once you are done, you can always do raster math to make sure
> data has not changed. ( original layer - new layer should give zeros).
> For your second question, that is just the way it is! Since QGIS is open
> source, not ever programmer puts reprojection in their code.
> Cheers.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> www.archeotec.ca
> On Jun 10, 2015 4:36 PM, "ardi [via OSGeo.org]" <[hidden email]> wrote:
> Hi,
> I've a satellite photo data set which spans across three UTM zones,
> and I need to do some tasks in all three zones at once. Each image
> tile from the data set is provided in two versions: one is projected
> in the UTM coordinate system for the zone it actually belongs. The
> other is projected over the central UTM zone, extending such central
> zone.
> AFAIK, QGIS can deal with layers belonging to different UTM zones,
> because you see a lat/long display and layers are reprojected to
> lat/long on the fly.
> My question is: can I save disk space by storing the image tiles in
> just one version, the version projected in its real UTM zone? Or would
> I also need the versions projected into the (extended) central UTM
> zone?
> Just out of curiosity, what's the use of the version projected into
> the extended zone? Is it because some GIS packages don't support
> on-the-fly reprojection? Or why?
> Thank you in advance
> Qgis-user mailing list
> <a
> href="/user/SendEmail.jtp?type=node&node=5210266&i=0">[hidden
> email]
> ________________________________
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Do-I-need-satellite-raster-layers-relative-to-an-extended-UTM-zone-tp5210266.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a
> href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
> here.
> <a
> href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml"
> style="font:9px serif">NAML
> View this message in context: Re: Do I need satellite raster layers relative
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
