[Qgis-user] Field calculator - output layer CRS bug
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Thu Jun 11 18:23:37 PDT 2015
I don't use the field calculator in models but I would ask myself the following questions: Is there a projection file associated with the input .shp file?  Is that projection the same as the project or are you relying on projection on the fly?  If your using modules from an other program, does the program support that projection?
You can also try to see if you can use another function instead or maybe you can add the projection afterwards.
Hopefully, you will get an answer from someone who uses the field calculator the graphical modeler.
Cheers!
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Jun 11, 2015 8:16 PM, "dabraham [via OSGeo.org]" <ml-node+s1560n5210512h33 at n6.nabble.com> wrote:
	Hi, when I use the field calculator through the graphical modeler, the output layer hasn't assigned CRS. Any other algorithm, which I tried, applied CRS from input layer. Why field calculator doesn't work as well? Thanks for any advice Dominik
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Field-calculator-output-layer-CRS-bug-tp5210512.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Field-calculator-output-layer-CRS-bug-tp5210512p5210514.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150611/5f01f54e/attachment.html>
