[Qgis-user] [Qgis-developer] QGIS 2.8.2 for RHEL/EPEL 7
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Fri Jun 12 12:15:23 PDT 2015
Hi everyone,
I have tried to install QGIS 2.8.2 from the http://koji.fedoraproject.org/koji/taskinfo?taskID=9997800 and I got stuck with dependencies:
I started to look after rpm files where are those libraries and they are all over the place. I picked rpm.pbone.net.
Initially everything was good until I reached some version conflicts like qt4-core. For this specific I have to choose among: 4.8.6-2, 4.8.5-8, 4.8.5-1 etc.
Is any place where those dependencies are or should I continue googling foe each dependency?
Thanks,
Marian
From: Dave Johansen [mailto:davejohansen at gmail.com]
Sent: June-10-15 10:55 AM
To: richard at duif.net
Cc: qgis-developer at lists.osgeo.org; Matthias Kuhn; Tudorache, Marian; Alex Mandel; Angelos Tzotsos
Subject: Re: [Qgis-developer] QGIS 2.8.2 for RHEL/EPEL 7
On Wed, Jun 10, 2015 at 1:51 AM, Richard Duivenvoorde <rdmailings at duif.net<mailto:rdmailings at duif.net>> wrote:
On 10-06-15 06:58, Dave Johansen wrote:
> I just built QGIS 2.8.2 for RHEL/EPEL 7 (
> http://koji.fedoraproject.org/koji/taskinfo?taskID=9997800 ) and it is
> available in the testing repo (
> https://admin.fedoraproject.org/updates/qgis-2.8.2-1.el7 ). I built it
> without PyQwt because it doesn't support Qwt 6 (
> http://lists.osgeo.org/pipermail/qgis-developer/2014-December/036112.html ),
> so I'm sure that some functionality is disabled and/or won't work but
> the main application is available for testing.
Hi Dave et al,
Thanks, can you maybe also let us know how you would add this repo, so
we can maybe update the instructions?
To me it looks like the instructions here:
http://qgis.org/en/site/forusers/alldownloads.html#rhel-centos-scientific-linux
are not working anymore for recent versions of RHEL/CentSO, but please
correct me if I'm wrong.
The instructions to enable use of the EPEL repositories can be found here:
https://fedoraproject.org/wiki/EPEL/FAQ#How_can_I_install_the_packages_from_the_EPEL_software_repository.3F
I'm not sure if we have an official 'maintainer' of QGIS for the
RedHat/.rpm based distro's currently.
For the sake of the project I think it is good if we have working
instructions for rpm based distro's.
I'm currently the owner/packager for EPEL 6/7. That's obviously not a "QGIS role" but a Fedora one.
From Alex I understood that Angelos is maintaining a build server, which
maybe also able to build rpm's?
https://en.opensuse.org/openSUSE:Build_Service_cross_distribution_howto
We should maybe also tell people if is too hard/impossible to install
QGIS or QGIS-server on a RHEL/CentOS version (as I understand on RHEL5.5
it's not doable because of a lack of certain Qt libs)..
I believe that we could build QGIS 1.8 on RHEL 5 without too much problem. I'm currently only really interested in RHEL 6 and 7, but if there was interest in supporting QGIS 1.8 on RHEL 5, then I would be glad to do that as well.
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150612/06c2d6a6/attachment.html>
