[Qgis-user] [Qgis-developer] QGIS 2.8.2 for RHEL/EPEL 7
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Mon Jun 15 09:50:52 PDT 2015
Thanks Dave,
I do not know if this helps but I think I found a circular dependency among some of the packages related to PyQt4.
1. When I tried to install the package: PyQt4-4.10.1-13.el7.x86_64 I got an unsatisfied dependency on libphonon.so.4()(64bit)
2. I have found libphonon.so.4()(64bit) on phonon-4.6.0-9.el7.x86_64.rpm.
3. But phonon-4.6.0-9.el7.x86_64.rpm requires phonon-backend(x86-64) >= 4.4.
4. I have found phonon-backend(x86-64) >= 4.4 on phonon-backend-gstreamer-4.6.3-3.el7.x86_64.rpm.
5. But phonon-backend-gstreamer-4.6.3-3.el7.x86_64.rpm requires libphonon.so.4()(64bit) and phonon(x86-64) >= 4.6.0.
6. Both libphonon.so.4()(64bit) and phonon(x86-64) >= 4.6.0 exists in phonon-4.6.0-9.el7.x86_64.rpm
7. So I am back at the step 3
Marian
From: Dave Johansen [mailto:davejohansen at gmail.com]
Sent: June-13-15 12:29 PM
To: Tudorache, Marian
Cc: richard at duif.net; Matthias Kuhn; Alex Mandel; Angelos Tzotsos; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-developer] QGIS 2.8.2 for RHEL/EPEL 7
On Fri, Jun 12, 2015 at 12:15 PM, Tudorache, Marian <Marian.Tudorache at navcanada.ca<mailto:Marian.Tudorache at navcanada.ca>> wrote:
Hi everyone,
I have tried to install QGIS 2.8.2 from the http://koji.fedoraproject.org/koji/taskinfo?taskID=9997800 and I got stuck with dependencies:
I started to look after rpm files where are those libraries and they are all over the place. I picked rpm.pbone.net<http://rpm.pbone.net>.
Initially everything was good until I reached some version conflicts like qt4-core. For this specific I have to choose among: 4.8.6-2, 4.8.5-8, 4.8.5-1 etc.
Is any place where those dependencies are or should I continue googling foe each dependency?
https://admin.fedoraproject.org/updates/FEDORA-EPEL-2015-6639/qgis-2.8.2-1.el7
There's a missing dependency in EPEL for python-OWSLib. I'll look into fixing that.
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150615/37579671/attachment.html>
