[Qgis-user] Local Government for QGIS
Andreas Neumann a.neumann at carto.net
Mon Jun 15 02:38:48 PDT 2015
Hi Micha,
Thanks again for your response. I will discuss this with the devs and
will probably come up with a proposal, asking for some organizations to
join the funding.
Andreas
On 15.06.2015 10:28, Micha Silver wrote:
> Hi Andreas:
> Thanks for your response.
> I'm quite sure that for most regional councils here, DXF would not be
> enough. The surveyors and planners that we work with all use Autodesk
> products. All their work is delivered in dwg, and some do not even
> know that there is such a thing as DXF.
> I have not been following the Open Design Alliance lately, but
> including that library QGIS would certainly be a quantum leap forward.
> After Radim's success in crowd funding the implementation of GRASS 7,
> your suggestion indeed sounds feasible.
> Regards,
> Micha
> On 6/15/2015 10:28 AM, Andreas Neumann wrote:
>> Hi Micha,
>> That is interesting - we invested a lot in the DXF export
>> capabilities of QGIS. Once this is finished I am pretty sure we will
>> also look to improve the situation regarding the import.
>> Do you think import of DXF is enough or do we also need DWG support?
>> If so, the best bet would probably be the Teigha library from the
>> (https://www.opendesign.com/the_oda_platform/Teigha), which isn't
>> available for free - but it is the library most other GIS (eg. ESRI,
>> Intergraph) and CAD (eg. Bentley, Bricscad, etc.) are using. We would
>> have to pay a membership fee, but it allows us to redistribute the
>> library with the software. Membership in the consortium is affordable
>> in my opinion.
>> What are your thoughts on this? Would you also be available to help
>> with a crowd-funding effort? Do you see options besides Teigha?
>> Andreas
>> On 15.06.2015 08:57, Micha Silver wrote:
>>> On 06/15/2015 09:23 AM, Bernhard Ströbl wrote:
>>>> Hi Joseph,
>>>> could you elaborate why "it would be unrealistic to say we
>>>> could ever be a 100% QGIS"? I am curious because I lost contact
>>>> with ESRI products a couple years ago.
>>> From our point of view, we need support for dwg. That side of vendor
>>> lock-in is, unfortunately, even stronger that the ties to ESRI. So
>>> we stay with Arc* not because of the GIS capabilites, but more or
>>> less only because of the ability to read Autocad plans and surveys.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> This mail was received via Mail-SeCure System.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150615/76633b27/attachment.html>
