[Qgis-user] [Qgis-developer] QGIS 2.8.2 for RHEL/EPEL 7
Dave Johansen
davejohansen at gmail.com
Mon Jun 15 17:00:09 PDT 2015
On Mon, Jun 15, 2015 at 1:57 PM, Tudorache, Marian <
Marian.Tudorache at navcanada.ca> wrote:
> Hi Dave,
> Thank you for your answer.
> I was looking in this repository:
> http://koji.fedoraproject.org/koji/packageinfo?packageID=4717.
> There are several builds. Which one should I test when the new
> python-OWSLib will be available.
> By the way where I can find some instruction of how to install it.
> The way that I did (and I am not sure is right).
> I downloaded from
> http://koji.fedoraproject.org/koji/buildinfo?buildID=644614 the
> followings:
> qgis-2.8.2-1.el7.x86_64.rpm;
> qgis-devel-2.8.2-1.el7.x86_64.rpm;
> qgis-grass-2.8.2-1.el7.x86_64.rpm;
> qgis-python-2.8.2-1.el7.x86_64.rpm;
> qgis-server-2.8.2-1.el7.x86_64.rpm;
> qgis-debuginfo-2.8.2-1.el7.x86_64.rpm;
> and I started with:
> yum install qgis-2.8.2-1.el7.x86_64.rpm
> I got a list of dependency then I started to search for an rpm which
> contain the dependency and so one and so for.
> At some point I went into a cycle dependency which I thought I solve it
> but it did not work.
> I will appreciate if you can advise me.
There are several helps/examples/tutorials online about how to install
packages with yum, so I'll direct you to one of those.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150615/cf1cfbd5/attachment.html>
