[Qgis-user] QGIS scale bar - fixing the width
Andreas Neumann
a.neumann at carto.net
Tue Jun 16 07:27:10 PDT 2015
Hi Chris,
This is a known limitation of QGIS - the graphical scalebar doesn't work
well with changes in map scale. Version 2.10 (to be released in 1.5-2
weeks) addresses this issue by introducing a new option called "Fit
segment width" (see image below) where the map units are adopted and the
segment length varies between min/max ranges. This works very well
across all map scales.
Until then you would either have to avoid the graphical scale-bar and
replace it with a numerical one, or you have to manually adjust the
scalebar after each change in map scale ;-(
Andreas
On 16.06.2015 16:18, Chris Buckmaster wrote:
> Hi
> Is there a way that I can set it so that the scale bar keeps the width
> on the page based on the actual relative width rather than keeping the
> width based on the map units? Example below the first image shows what
> it looks like at a scale of 1:1250, and the second image shows what it
> looks like at a scale of 1:200 (ideally I want the scale bar to keep
> the same width as the second image, but change the map units).
> Thanks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150616/bb91e243/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150616/bb91e243/attachment.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150616/bb91e243/attachment-0001.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150616/bb91e243/attachment-0002.png>
