[Qgis-user] QGIS scale bar - fixing the width
Chris Buckmaster
chris.buckmaster at runnymede.gov.uk
Tue Jun 16 07:30:53 PDT 2015
Hi Andreas
Ah no problem then if there is going to be a solution - great to hear!
Thanks, Chris
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: 16 June 2015 15:27
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS scale bar - fixing the width
Hi Chris,
This is a known limitation of QGIS - the graphical scalebar doesn't work well with changes in map scale. Version 2.10 (to be released in 1.5-2 weeks) addresses this issue by introducing a new option called "Fit segment width" (see image below) where the map units are adopted and the segment length varies between min/max ranges. This works very well across all map scales.
Until then you would either have to avoid the graphical scale-bar and replace it with a numerical one, or you have to manually adjust the scalebar after each change in map scale ;-(
Andreas
[cid:image001.png at 01D0A849.6E22AE70]
On 16.06.2015 16:18, Chris Buckmaster wrote:
Hi
Is there a way that I can set it so that the scale bar keeps the width on the page based on the actual relative width rather than keeping the width based on the map units? Example below the first image shows what it looks like at a scale of 1:1250, and the second image shows what it looks like at a scale of 1:200 (ideally I want the scale bar to keep the same width as the second image, but change the map units).
[cid:image002.png at 01D0A849.6E22AE70]
[cid:image003.png at 01D0A849.6E22AE70]
Thanks
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150616/a07ad31e/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150616/a07ad31e/attachment.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150616/a07ad31e/attachment-0001.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150616/a07ad31e/attachment-0002.png>
