[Qgis-user] QGIS Composer: exported image doesn't have the world file
    Andreas Neumann
    a.neumann at carto.net
    Thu Jun 18 01:06:15 PDT 2015
hm on my system with QGIS master I don't get the world file. Is there
some setting?
it works fine from the QGIS main window,  but not from the print
composer. But then I don't understand how it should work anyway. If you
have multiple maps on the composer - which one should be used for the
worldfile. I don't see much point in exporting a world file from print
composer.
If the only reason is the increased dpi support we should add the
DPI-setting to the export in main QGIS and not support world files in
print composer.
Andreas
On 18.06.2015 10:00, Salvatore Larosa wrote:
> Hi,
> On Thu, Jun 18, 2015 at 12:28 AM, skampus <skampus at gmail.com> wrote:
>> hi,
>> i see that the print composer doesn't allow to export the layout as an image
>> with its proper world file anymore.
>> i seem that previous versions had this possibility.
>> is this a regression?
>> do i have to open a ticket?
> with both 2.8 and developing versions I am able to export a world file
> from composer.
> This feature was introduced since the 2.2 version. Which version are
> you trying with?
