[Qgis-user] QGIS Composer: exported image doesn't have the world file
    Bernhard Ströbl
    bernhard.stroebl at jena.de
    Thu Jun 18 01:17:24 PDT 2015
Hi Andreas,
I can imagine users wanting to export a "map" with legend, annotations
etc. with world file e.g. to serve through WMS or give to third parties
(I am not judging if this is a sensible wish :) So why not support it
and have the user set the map to be used if several maps are in the
composer? This is especially true if it used to work in former versions
(I do not know if this is true, though)
my 2 cents
Bernhard
Am 18.06.2015 um 10:06 schrieb Andreas Neumann:
> hm on my system with QGIS master I don't get the world file. Is there
> some setting?
> it works fine from the QGIS main window,  but not from the print
> composer. But then I don't understand how it should work anyway. If you
> have multiple maps on the composer - which one should be used for the
> worldfile. I don't see much point in exporting a world file from print
> composer.
> If the only reason is the increased dpi support we should add the
> DPI-setting to the export in main QGIS and not support world files in
> print composer.
> Andreas
> On 18.06.2015 10:00, Salvatore Larosa wrote:
>> Hi,
>> On Thu, Jun 18, 2015 at 12:28 AM, skampus <skampus at gmail.com> wrote:
>>> hi,
>>> i see that the print composer doesn't allow to export the layout as
>>> an image
>>> with its proper world file anymore.
>>> i seem that previous versions had this possibility.
>>> is this a regression?
>>> do i have to open a ticket?
>> with both 2.8 and developing versions I am able to export a world file
>> from composer.
>> This feature was introduced since the 2.2 version. Which version are
>> you trying with?
> Qgis-user mailing list
> __________ Information from ESET Mail Security, version of virus
> signature database 11804 (20150618) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 11804 (20150618) __________
http://www.eset.com
