[Qgis-user] Field calculator
Matthias Kuhn
matthias.kuhn at gmx.ch
Thu Jun 18 13:41:24 PDT 2015
Hi Nicolas,
I think at the moment there is no way to achieve that without explicitly
stating the layer id or name in the expression itself, since the layer
is not known to the expression. This will probably change soon with the
introduction of the "Expression Context" work by Nyall Dawson.
If it is an option for you to specify the layer name, you can use the
map layer registry to find the layer and then use the dataSourceUri of
the provider of this layer to find the file name.
Regards,
Matthias
On 06/18/2015 09:39 PM, Nicolas Cadieux wrote:
> Hi,
> I need to use the field calculator to add the file name or layer name to a new field. Is there an expression for that? If not, can someone help me with the function Editor?
> Thanks
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> www.archeotec.ca
> Qgis-user mailing list
