[Qgis-user] Field calculator
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sat Jun 20 06:06:41 PDT 2015
Thanks for the help Matthias.
Apparently Saga has a module that will merge shape files and has an option to specify the source file name. This is what I needed as I have thousands of files to merge.
Is't for a Lidar file index but lastools does not have that option.
Thanks for the help.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jun 18, 2015 4:41 PM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Hi Nicolas,
> I think at the moment there is no way to achieve that without explicitly
> stating the layer id or name in the expression itself, since the layer
> is not known to the expression. This will probably change soon with the
> introduction of the "Expression Context" work by Nyall Dawson.
> If it is an option for you to specify the layer name, you can use the
> map layer registry to find the layer and then use the dataSourceUri of
> the provider of this layer to find the file name.
> Regards,
> Matthias
> On 06/18/2015 09:39 PM, Nicolas Cadieux wrote:
> > Hi,
> > I need to use the field calculator to add the file name or layer name to a new field. Is there an expression for that? If not, can someone help me with the function Editor?
> > Thanks
> > www.archeotec.ca
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
