[Qgis-user] Merging Shapefiles on Top of Each Other
David Fawcett
david.fawcett at gmail.com
Fri Jun 19 07:05:35 PDT 2015
Tom,
As Matt says, you don't need to combine the roads and sectors into the same
dataset to display them together in QGIS. You can add both separate
datasets to a map and you can order the layers so that the roads are drawn
after the polygons.
David.
On Thu, Jun 18, 2015 at 11:02 PM, Matt Boyd <mattslists at gmail.com> wrote:
> Hi Tom,
> Have a look at some of the QGIS tutorials (google or the QGIS website
> shoudl have some). It sounds like you just need to overlay the layers in
> the correct order, merge generally means something else.
> You can drag / move the layers around / up / down in the layers window.
> Generally from top to bottom, points, lines, polygons. There is also an
> option to give each layer a level of transparency.
> On Thu, Jun 18, 2015 at 8:59 PM, Tom Faro <Tom.Faro at zenith-insurance.co.uk
> > wrote:
>> I have been having some trouble with merging two shapefiles – one is a
>> map of all sectors in the UK and one is a map of all motorways in the UK. I
>> have successfully merged them by putting them both as polygons. However,
>> when I fill in the sectors with different colours the road map disappears.
>> The same happens when I use the same shapefile in other software.
>> Is it possible to merge them so that the roads are always on top? Any
>> Help with this matter would be greatly appreciated.
>> Many Thanks,
>> Tom
>> [image: Environment]
>> Zenith Insurance Management UK Limited is an appointed service provider
>> to Zenith Insurance plc and is not an Agent of Zenith Insurance plc. Zenith
>> and Link are the European brands of the Markerstudy Group of Companies.
>> Zenith Insurance Management UK Limited (Registered No. 5309111). Link
>> Underwriting Agency Limited (Registered No. 4227586). Both companies are
>> registered in England & Wales at Chester House, Harlands Road, Haywards
>> Heath, West Sussex, RH16 1LR. Zenith Insurance Management UK Limited is
>> authorised and regulated by the Financial Conduct Authority (No. 429279).
>> For security and training purposes, all calls may be monitored or recorded.
>> Any views of opinions expressed in this e-mail are solely those of the
>> author and do not necessarily represent those of the Markerstudy Group of
>> Companies. This message (and any attachments) contains information that may
>> be confidential and protected from disclosure. If you are not the intended
>> recipient of this message or any parts of it, please immediately contact
>> the sender and delete the message from your system. No other person is
>> authorised to copy, forward, distribute, disseminate or retain this message
>> in any form.
>> This email message has been scanned for viruses by Mimecast.
>> Mimecast delivers a complete managed email solution from a single web
>> based platform.
>> For more information please visit http://www.mimecast.com
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150619/8154f6bd/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150619/8154f6bd/attachment.gif>
