[Qgis-user] Merging Shapefiles on Top of Each Other
Tom Faro
Tom.Faro at zenith-insurance.co.uk
Mon Jun 22 00:55:38 PDT 2015
Hi David,
My apologies to both you and Matt as I should have been clearer. My aim is to merge them both so that I can use this shapefile in another piece of software (which will only accept one shapefile to be viewed at a time). However, what you are both suggesting does work perfectly if I want to stay in QGIS, so thanks very much for your help!
Regards,
Tom
[cid:image007.jpg at 01D0ACC9.A48A37B0]
Tom Faro
Pricing Analyst
Zenith Insurance Management UK Ltd
E-Mail :
Web :
www.zenith-insurance.co.uk<http://www.zenith-insurance.co.uk>
Address :
Chester House, Harlands Road, Haywards Heath, West Sussex, RH16 1LR
[cid:image003.jpg at 01D0ACC9.A2AB6590] [cid:image004.jpg at 01D0ACC9.A2AB6590]
Zenith Insurance Management UK Limited, a part of the Markerstudy Group of Companies
[cid:image005.jpg at 01D0ACC9.A2AB6590]
From: David Fawcett [mailto:david.fawcett at gmail.com]
Sent: 19 June 2015 15:06
To: Matt Boyd
Cc: Tom Faro; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Merging Shapefiles on Top of Each Other
Tom,
As Matt says, you don't need to combine the roads and sectors into the same dataset to display them together in QGIS. You can add both separate datasets to a map and you can order the layers so that the roads are drawn after the polygons.
David.
On Thu, Jun 18, 2015 at 11:02 PM, Matt Boyd <mattslists at gmail.com<mailto:mattslists at gmail.com>> wrote:
Hi Tom,
Have a look at some of the QGIS tutorials (google or the QGIS website shoudl have some). It sounds like you just need to overlay the layers in the correct order, merge generally means something else.
You can drag / move the layers around / up / down in the layers window. Generally from top to bottom, points, lines, polygons. There is also an option to give each layer a level of transparency.
On Thu, Jun 18, 2015 at 8:59 PM, Tom Faro <Tom.Faro at zenith-insurance.co.uk<mailto:Tom.Faro at zenith-insurance.co.uk>> wrote:
I have been having some trouble with merging two shapefiles – one is a map of all sectors in the UK and one is a map of all motorways in the UK. I have successfully merged them by putting them both as polygons. However, when I fill in the sectors with different colours the road map disappears. The same happens when I use the same shapefile in other software.
Is it possible to merge them so that the roads are always on top? Any Help with this matter would be greatly appreciated.
Many Thanks,
Tom
[Environment]
Zenith Insurance Management UK Limited is an appointed service provider to Zenith Insurance plc and is not an Agent of Zenith Insurance plc. Zenith and Link are the European brands of the Markerstudy Group of Companies.
Zenith Insurance Management UK Limited (Registered No. 5309111). Link Underwriting Agency Limited (Registered No. 4227586). Both companies are registered in England & Wales at Chester House, Harlands Road, Haywards Heath, West Sussex, RH16 1LR. Zenith Insurance Management UK Limited is authorised and regulated by the Financial Conduct Authority (No. 429279). For security and training purposes, all calls may be monitored or recorded.
Any views of opinions expressed in this e-mail are solely those of the author and do not necessarily represent those of the Markerstudy Group of Companies. This message (and any attachments) contains information that may be confidential and protected from disclosure. If you are not the intended recipient of this message or any parts of it, please immediately contact the sender and delete the message from your system. No other person is authorised to copy, forward, distribute, disseminate or retain this message in any form.
This email message has been scanned for viruses by Mimecast.
Mimecast delivers a complete managed email solution from a single web based platform.
For more information please visit http://www.mimecast.com
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/04429c3e/attachment.html>
Type: image/jpeg
Desc: image003.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/04429c3e/attachment.jpg>
Type: image/jpeg
Desc: image004.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/04429c3e/attachment-0001.jpg>
Type: image/jpeg
Desc: image005.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/04429c3e/attachment-0002.jpg>
Type: image/gif
Desc: image006.gif
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/04429c3e/attachment.gif>
Type: image/jpeg
Desc: image007.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/04429c3e/attachment-0003.jpg>
