[Qgis-user] Merging Shapefiles on Top of Each Other
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Jun 22 01:33:16 PDT 2015
If you want one shapefile only, you might want a topologically correct
file, i.e., no overlapping polygons / boundaries. These could be created
using the v.clean function (a GRASS function available in the QGIS toolbox).
On Mon, Jun 22, 2015 at 9:55 AM, Tom Faro <Tom.Faro at zenith-insurance.co.uk>
wrote:
> Hi David,
> My apologies to both you and Matt as I should have been clearer. My aim is
> to merge them both so that I can use this shapefile in another piece of
> software (which will only accept one shapefile to be viewed at a time).
> However, what you are both suggesting does work perfectly if I want to stay
> in QGIS, so thanks very much for your help!
> Regards,
> Tom
> Tom Faro
> Pricing Analyst
> Zenith Insurance Management UK Ltd
> E-Mail :
> Web :
> www.zenith-insurance.co.uk
> Address :
> Chester House, Harlands Road, Haywards Heath, West Sussex, RH16 1LR
> Zenith Insurance Management UK Limited, a part of the Markerstudy Group of
> Companies
> *From:* David Fawcett [mailto:david.fawcett at gmail.com]
> *Sent:* 19 June 2015 15:06
> *To:* Matt Boyd
> *Cc:* Tom Faro; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Merging Shapefiles on Top of Each Other
> Tom,
> As Matt says, you don't need to combine the roads and sectors into the
> same dataset to display them together in QGIS. You can add both separate
> datasets to a map and you can order the layers so that the roads are drawn
> after the polygons.
> David.
> On Thu, Jun 18, 2015 at 11:02 PM, Matt Boyd <mattslists at gmail.com> wrote:
> Hi Tom,
> Have a look at some of the QGIS tutorials (google or the QGIS website
> shoudl have some). It sounds like you just need to overlay the layers in
> the correct order, merge generally means something else.
> You can drag / move the layers around / up / down in the layers window.
> Generally from top to bottom, points, lines, polygons. There is also an
> option to give each layer a level of transparency.
> On Thu, Jun 18, 2015 at 8:59 PM, Tom Faro <Tom.Faro at zenith-insurance.co.uk>
> wrote:
> I have been having some trouble with merging two shapefiles – one is a map
> of all sectors in the UK and one is a map of all motorways in the UK. I
> have successfully merged them by putting them both as polygons. However,
> when I fill in the sectors with different colours the road map disappears.
> The same happens when I use the same shapefile in other software.
> Is it possible to merge them so that the roads are always on top? Any Help
> with this matter would be greatly appreciated.
> Many Thanks,
> Tom
> [image: Environment]
> Zenith Insurance Management UK Limited is an appointed service provider to
> Zenith Insurance plc and is not an Agent of Zenith Insurance plc. Zenith
> and Link are the European brands of the Markerstudy Group of Companies.
> Zenith Insurance Management UK Limited (Registered No. 5309111). Link
> Underwriting Agency Limited (Registered No. 4227586). Both companies are
> registered in England & Wales at Chester House, Harlands Road, Haywards
> Heath, West Sussex, RH16 1LR. Zenith Insurance Management UK Limited is
> authorised and regulated by the Financial Conduct Authority (No. 429279).
> For security and training purposes, all calls may be monitored or recorded.
> Any views of opinions expressed in this e-mail are solely those of the
> author and do not necessarily represent those of the Markerstudy Group of
> Companies. This message (and any attachments) contains information that may
> be confidential and protected from disclosure. If you are not the intended
> recipient of this message or any parts of it, please immediately contact
> the sender and delete the message from your system. No other person is
> authorised to copy, forward, distribute, disseminate or retain this message
> in any form.
> This email message has been scanned for viruses by Mimecast.
> Mimecast delivers a complete managed email solution from a single web
> based platform.
> For more information please visit http://www.mimecast.com
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/c1b0b4bc/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/c1b0b4bc/attachment.jpg>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/c1b0b4bc/attachment.gif>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/c1b0b4bc/attachment-0001.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/c1b0b4bc/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/c1b0b4bc/attachment-0003.jpg>
