[Qgis-user] Error loading plugin QspatialLite
Tudorache, Marian Marian.Tudorache at navcanada.ca
Fri Jun 19 15:09:20 PDT 2015
I have tried to load QSpatialLite plugin and I got an error.:
The plugin seems to be invalid or have unfulfilled dependencies. It has been installed, but can't be loaded.
The message says if I need this plugin contact the author or Qgis user group.
Later the message says: No module name pyspatialite.
Does someone has this experience?
Thanks,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le pr?sent message ?lectronique et tout fichier qui peut y ?tre joint peuvent contenir des renseignements privil?gi?s ou confidentiels destin?s ? l'usage exclusif des personnes ou des organismes ? qui ils s'adressent. Si vous avez re?u ce message ?lectronique par erreur, veuillez en informer l'exp?diteur imm?diatement et supprimez le. Toute reproduction, divulgation ou distribution du pr?sent message ?lectronique est strictement interdite. NAV CANADA n'assume aucune responsabilit? en cas de dommage caus? par tout virus ou autre programme malveillant transmis par ce message ?lectronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150619/b2c2f5a9/attachment.html>
