[Qgis-user] labelling by attribute
Andreas Neumann a.neumann at carto.net
Sun Jun 21 02:15:05 PDT 2015
Hi Luca,
You can find the images also in the online archives of the mailing list:
http://lists.osgeo.org/pipermail/qgis-user/2015-June/032464.html (scroll
down to the bottom).
The issue with ArcGIS is that only a very small fraction of the devs and
users has access to ArcGIS - so unless you can point to some public
document that explains an issue or function (e.g. online version of
ArcGIS documentation) there is not much value in pointing us to "the way
ArcGIS" does it.
Greetings,
Andreas
On 20.06.2015 23:54, Luca Galuppini wrote:
> Dear Andreas,
> thank you for your hint, i just need to get used to a different
> environment. i didn't mean to make comparisons between arcgis and
> qgis, i know what are the differences between an open source project
> and a commercial software and i'm sorry if it sounded "bad", but
> really, the arcgis thing was only for better explaining what i meant
> and i hoped someone answered "yes, qgis has that function, just
> download this plugin / click on that small icon". anyway, the
> categorization function in the symbology section is almost identical
> to arcgis, that's why i expected something similar also in the
> labelling section!
> that said, do you have a link for your attachments? i cant see them as
> i'm reading in digest mode
> 2015-06-20 21:00 GMT+02:00 <qgis-user-request at lists.osgeo.org
> <mailto:qgis-user-request at lists.osgeo.org>>:
>     Send Qgis-user mailing list submissions to
>     qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>     To subscribe or unsubscribe via the World Wide Web, visit
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
>     or, via email, send a message with subject or body 'help' to
>     You can reach the person managing the list at
>     qgis-user-owner at lists.osgeo.org
>     <mailto:qgis-user-owner at lists.osgeo.org>
>     When replying, please edit your Subject line so it is more specific
>     than "Re: Contents of Qgis-user digest..."
>     Today's Topics:
>        1. Re: labelling by attribute (James Keener)
>        2. Re: labelling by attribute (Andreas Neumann)
>        3. Re: labelling by attribute (James Keener)
>        4. shapefile (Chandler Coleman)
>        5. Re: shapefile (Nicolas Cadieux)
>        6. Table output from QGIS graphical modeler (Dominik Abrah?m)
>     Message: 1
>     Date: Sat, 20 Jun 2015 11:10:53 -0400
>     From: James Keener <jim at jimkeener.com <mailto:jim at jimkeener.com>>
>     To: Andreas Neumann <a.neumann at carto.net
>     <mailto:a.neumann at carto.net>>, qgis-user at lists.osgeo.org
>     Subject: Re: [Qgis-user] labelling by attribute
>     Message-ID: <5585827D.2060608 at jimkeener.com
>     <mailto:5585827D.2060608 at jimkeener.com>>
>     Content-Type: text/plain; charset="windows-1252"
>     > 0.00xx percent of what ESRI has available in its budget.
>     And have an amazing piece of software to show for it!
>     > However, I agree with you, that rule-based or categorized labels
>     would
>     > be very useful to have in QGIS. In fact we know this for a long time
>     > already - since version 2.0 people have asked for it. But - it
>     is quite
>     > a lot of work to implement. If you need this, consider
>     sponsoring it or
>     > start a crowd-funding initiative.
>     There was talk in another email thread about doing something
>     similar for
>     AutoCAD support.
>     In all seriousness, what would be the process of doing this?  Has this
>     been done for any other QGIS features?  Who would be paid? OSG,
>     specific
>     developers?  Who would we talk to about something like this?
>     Jim
>     -------------- next part --------------
>     A non-text attachment was scrubbed...
>     Type: application/pgp-signature
>     Desc: OpenPGP digital signature
>     URL:
>     <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150620/837e537e/attachment-0001.pgp>
>     Message: 2
>     Date: Sat, 20 Jun 2015 17:25:44 +0200
>     From: Andreas Neumann <a.neumann at carto.net
>     To: James Keener <jim at jimkeener.com <mailto:jim at jimkeener.com>>,
>     Message-ID: <558585F8.9040809 at carto.net
>     <mailto:558585F8.9040809 at carto.net>>
>     Content-Type: text/plain; charset=windows-1252; format=flowed
>     Hi Jim,
>     Thanks ;-) we try our best.
>     labels would
>     time
>     is quite
>     sponsoring it or
>     similar for
>     > AutoCAD support.
>     Yes - I will start working on a requirements document soon. I will
>     post
>     it on Google Docs so different people/organizations can contribute. In
>     the case of DXF/DWG, J?rgen Fischer of company Norbit will be able to
>     work on it. He also partially did the DXF export and knows the DXF
>     format quite well. For the import we will probably use a library
>     called
>     Teigha - the same library also used by ESRI, Bricscad, Intergraph and
>     many others. We will have to join the OpenDesignAlliance to get access
>     to this library and pay a yearly membership fee - we still have to
>     investigate which level of membership we need as an open source
>     project.
>     It is clear that the DWG import is harder than the DXF export, but the
>     Teigha library will help a lot.
>     Has this
>     specific
>     yes - absolutely - it has been done before. Maybe 2/3 of the
>     recent new
>     features were introduced because of paid development, and there
>     has been
>     some co-financed and/or crowd-funded development efforts. As an
>     example,
>     the DXF export was funded by 3 Swiss communities, the database
>     relations
>     and nested forms had been paid by some Swiss organizations. Many
>     other,
>     mostly middle-european local governments (e.g. Tuscany, french
>     ministry
>     of environment, Agence de l'eau Garonne, Province of Vorarlberg
>     (Austria) ...) have contributed and funded as well.
>     Recently, there have been two successful crowd-funding initiatives:
>     * QGIS GRASS Plugin Upgrade Crowdfunding:
>     http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
>     * QGIS live layer effects:
>     https://www.kickstarter.com/projects/41633306/a-christmas-gift-for-qgis-live-layer-effects-for-q
>     The QGIS PSC will invest some efforts to help such crowd funding
>     initiatives and make them more visible on our website, mailing
>     lists and
>     social media.
>     Besides the DWG import crowd funding effort, Nyall Dawson also
>     plans to
>     soon introduce a funding effort for print composer
>     rewrite/improvements
>     and a new reporting framework.
>     Andreas
>     Message: 3
>     Date: Sat, 20 Jun 2015 11:45:51 -0400
>     Message-ID: <55858AAF.5030100 at jimkeener.com
>     <mailto:55858AAF.5030100 at jimkeener.com>>
>     > Thanks we try our best.
>     But seriously, I've shown people who've only used Arc QGIS and
>     they love
>     it!  They find the interface easier to understand and use, and some of
>     them also really latch onto the idea of it being F/OSS (beer AND
>     speech)!  I only hope that at some point I have enough that I can give
>     back.  QGIS is amazing and may be in the process of changing the
>     flow of
>     my life (more on that in a few months if this works ::fingers
>     crossed::).
>     > For the import we will probably use a library called
>     Intergraph and
>     access
>     project.
>     but the
>     Not to argue, since I'm not the one doing the work (and it's a feature
>     that could help me out a bit!), but how does this mesh with GPLv2 and
>     the goal of being a F/OSS platform?
>     Has this
>     specific
>     recent new
>     has been
>     What's the process for going about this?  Let's say I want to start a
>     crowd funding campaign or fund a specific project. Would I contact the
>     PSC and hash out the feasibility and funding requirements?
>     Jim
>     URL:
>     <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150620/459582f1/attachment-0001.pgp>
>     Message: 4
>     Date: Sat, 20 Jun 2015 10:00:15 -0600
>     From: Chandler Coleman <chandcole at gmail.com
>     <mailto:chandcole at gmail.com>>
>     To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>     Subject: [Qgis-user] shapefile
>     Message-ID:
>     <CAPoscztEesrZEkA4caJqFH-PCXM_aCyqHKYt=iwVhOXbDgQrxQ at mail.gmail.com <mailto:iwVhOXbDgQrxQ at mail.gmail.com>>
>     Content-Type: text/plain; charset="utf-8"
>     HI,
>     I have a shapefile that shows up in a project.  But whne I open it
>     into
>     another project it doesn't show up. In another instance I had a
>     shapefile
>     that I opened an it showed up, but was so extremely larger then
>     what it
>     should have been.  I know this is a CRS issue, but not sure how to
>     correct.
>     Suggestions?
>     Thanks,
>     Chandler
>     An HTML attachment was scrubbed...
>     URL:
>     <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150620/a8315438/attachment-0001.html>
>     Message: 5
>     Date: Sat, 20 Jun 2015 10:12:35 -0700 (PDT)
>     From: Nicolas Cadieux <nicolas.cadieux at archeotec.ca
>     <mailto:nicolas.cadieux at archeotec.ca>>
>     Subject: Re: [Qgis-user] shapefile
>     Message-ID:
>     <16ea686b-4d75-4293-9ce1-618ffd1773e6 at email.android.com
>     <mailto:16ea686b-4d75-4293-9ce1-618ffd1773e6 at email.android.com>>
>     Hi,
>     In your QGIS option, make sure CRS on the fly is activated. Also
>     make sure that the "what to do if file has no CRS" is set to "ask"
>     so that QGIS does not assume the projection is the project
>     projection or a default CRS.
>     Once the file is open, if the file has no CRS (prj file,), QGIS
>     will ask for a projection.  At this point, you will need to add
>     one.  If you are not sure, you can try something logical like a
>     local CRS. (Informed guess).   Zoom to layer extent and see if you
>     are in the right spot.   If not, you can right click on the
>     layer and change the CRS and then zoom to extent again. Look at
>     the x and y.  Are you in meters or long\lat??? That will help
>     guessing. If you find the right CRS, you can save the file with
>     the new or corrected prj file in the "save as".
>     Nicolas Cadieux M.Sc.
>     Les Entreprises Archéotec inc.
>     8548, rue Saint-Denis Montréal H2P 2H2
>     Téléphone: 514.381.5112  Fax: 514.381.4995
>     www.archeotec.ca <http://www.archeotec.ca>
>     On Jun 20, 2015 11:56 AM, "chandcole [via OSGeo.org]"
>     <ml-node+s1560n5212093h44 at n6.nabble.com
>     <mailto:lt%3Bml-node%2Bs1560n5212093h44 at n6.nabble.com>> wrote:
>             HI, I have a shapefile that shows up in a project.? But
>     whne I open it into another project it doesn't show up. In
>     another instance I had a shapefile that I opened an it showed up,
>     but was so extremely larger then what it should have been.? I know
>     this is a CRS issue, but not sure how to correct. Suggestions?
>     Thanks, Chandler
>     _______________________________________________
>     [hidden email]
>                     If you reply to this email, your message will be
>     added to the discussion below:
>     http://osgeo-org.1560.x6.nabble.com/shapefile-tp5212093.html
>                     To start a new topic under Quantum GIS - User,
>     email ml-node+s1560n4125267h38@n6.nabble.com
>     <http://n6.nabble.com>
>                     To unsubscribe from Quantum GIS - User, click here .
>                     NAML
>     View this message in context:
>     http://osgeo-org.1560.x6.nabble.com/shapefile-tp5212093p5212098.html
>     Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>     URL:
>     <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150620/8b7634ab/attachment-0001.html>
>     Message: 6
>     Date: Sat, 20 Jun 2015 20:31:04 +0200
>     From: Dominik Abrah?m <dominikabraham at gmail.com
>     <mailto:dominikabraham at gmail.com>>
>     Subject: [Qgis-user] Table output from QGIS graphical modeler
>     Message-ID:
>     <CAJAEtKY6b6xEhW5B49jwD_Viy5-g86RfsGcnTVqzEDeRYY6DsA at mail.gmail.com <mailto:CAJAEtKY6b6xEhW5B49jwD_Viy5-g86RfsGcnTVqzEDeRYY6DsA at mail.gmail.com>>
>     Hi,
>     I have developed my own model, which processes input vector layer. The
>     final output is vector layer that contains many attribute fields,
>     and of
>     course, also the geometry, but I need a simpler output - geometry
>     and most
>     of those fields are unnecessary. With this model, how can I get a
>     simple
>     table output with selected attribute fields of the output layer?
>     Thanks for any advice.
>     Dominik
>     URL:
>     <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150620/089c0b70/attachment-0001.html>
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     End of Qgis-user Digest, Vol 112, Issue 52
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150621/e1cbb626/attachment.html>
