[Qgis-user] shapefile
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sat Jun 20 10:12:35 PDT 2015
In your QGIS option, make sure CRS on the fly is activated. Also make sure that the "what to do if file has no CRS" is set to "ask" so that QGIS does not assume the projection is the project projection or a default CRS.
Once the file is open, if the file has no CRS (prj file,), QGIS will ask for a projection. At this point, you will need to add one. If you are not sure, you can try something logical like a local CRS. (Informed guess). Zoom to layer extent and see if you are in the right spot. If not, you can right click on the layer and change the CRS and then zoom to extent again. Look at the x and y. Are you in meters or long\lat??? That will help guessing. If you find the right CRS, you can save the file with the new or corrected prj file in the "save as".
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jun 20, 2015 11:56 AM, "chandcole [via OSGeo.org]" <ml-node+s1560n5212093h44 at n6.nabble.com> wrote:
HI, I have a shapefile that shows up in a project. But whne I open it into another project it doesn't show up. In another instance I had a shapefile that I opened an it showed up, but was so extremely larger then what it should have been. I know this is a CRS issue, but not sure how to correct. Suggestions? Thanks, Chandler
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/shapefile-tp5212093.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/shapefile-tp5212093p5212098.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150620/8b7634ab/attachment.html>
