[Qgis-user] Qgis Windows : How to change default path for “.qgis2” folder
Richard Duivenvoorde
rdmailings at duif.net
Sun Jun 21 07:33:45 PDT 2015
Have a look at this blogpost:
http://qgis.dk/the-man-with-the-golden-gun-or-some-examples-of-installing-and-using-qgis-in-a-networked-environment/
and --configpath "THIS PATH" should work fine
it makes QGIS NOT look at your old .qgis2 folder, but create a new one
in D:\cci93\test_modify_config_path
Regards,
Richard
On 21-06-15 13:28, image93 wrote:
> Dear all,
> I'm working with windows 8 32 bits OS and qgis 2.8.2.
> The qgis default installing path for ".qgis2" folder is
> C:\Users\image95.qgis2. This directory stores several usefull components
> like qgis extensions, svg images or cache.
> I want really to move the location of this directory toward my D: disk
> That's why, i edited the qgis.bat file and i added the following line :
> --configpath "D:\cci93\test_modify_config_path"
> So, currently, my qgis.bat file is like that :
> <http://osgeo-org.1560.x6.nabble.com/file/n5212125/qgis.jpg>
> Unfortunatly, my attempt did not seem to have the expected effect.When i
> restart qgis and i install new extensions, the installation directory seems
> to be always the C:\Users\image95.qgis2 . Moreover, the extensions installed
> earlier are no longer availaible and usable.
> Could you tell me the way in order to change reliably and properly the path
> of the directory ".qgis2"?
> In advance, thank you very much.
> Kind regards.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-Windows-How-to-change-default-path-for-qgis2-folder-tp5212125.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
